IH PARTS AMERICA (https://forums.ihpartsamerica.com/index.php)
-   IH Parts America Product Questions (https://forums.ihpartsamerica.com/forumdisplay.php?f=16)
-   -   What is the difference between a disc brake wheel and drum wheel? (https://forums.ihpartsamerica.com/showthread.php?t=14085)
TJOSBOX 09-19-2018 08:52 PM
I am looking at the front disc conversion for my 1969 800a. The instructions state that I may need to swap my front wheels. How can I tell? I want to post a picture but cannot at the moment because of the link restriction
The narrowest section of the wheel when measured from the inside is about 12.5".
Also, your disc kit comes with a master cylinder. I just put a new one in, thought the reservoires are the same size. Do I actually need a new MC?
Thanks!
Re: What is the difference between a disc brake wheel and drum wheel?
Wait for it
Hondo 09-20-2018 12:42 AM
I have a 72 Scout with drums in front and a 75 Scout with discs in front. The wheels/rims from my drum break scout will not clear the calipers on my disc brake Scout
TJOSBOX 09-20-2018 07:18 AM
Another post, to unlock "picture posting power"
Michael Dimock 09-20-2018 07:49 AM
The disc brake wheels are very "square" on the inside with the drum brake wheels being angled by the wheel mounting flange. All the factory S80/800 15" and 16" wheels won't work with the disc brakes.
The disc brake master cylinder has a larger reservoir for the front brakes as well as no residual pressure. We recommend replacing the master cylinder to the disc brake version. Thanks.
TJOSBOX 09-20-2018 09:47 AM
@Michael - I found some images of the stock wheel online and I see what you mean. I do not have stock wheels so may be in luck? The inner diameter of the narrow section of the wheel (where the ring of rivets are) as measured from the inside is about 12.5"https://i.postimg.cc/X7MY3Szs/20180915_150229_HDR_1.jpg
TJOSBOX 09-21-2018 03:46 PM
Are there any additional measurements I need to check to know if this 15" wheel will work with the disc brakes?
Michael Dimock 09-25-2018 08:15 AM
If directly above the brake drum area is 12.5" in diameter, then it won't fit over a caliper. If that measurement is more over the wheel mounting surface and it gets larger over the drum, then you should be fine. Thanks.
