Carburetor Options?
BinderWalker
68 1200C V345E 4x4 4bbl
Application: A quick spin to the neighborhood garden and an occasional Sunday visit with the wife to church. This is a frame-off totally complete (every single nut & bolt) restoration including the Dana 40 & 60, 345E (that I pulled from a LS1700), T-16, & NP202. I hope to have it ready for Springfield / Ft Wayne 2026.
Question: The 4 (equally-sized) bores in the intake (spreadbore) that I have coupled with a manual choke, what carb should I be looking for?
Thanks Mr. Chappie, I found a little something from January of this year - but nothing in detail, and it was focused on a 2bbl. Yes, if you've got some info related to a 4bbl (especially the tuning specs), I'd be most interested. Thank you
Let me try this again. It's obvious you've built some compression here & probably have something that could pull stumps.
All I'm looking for is the "ideal" 4-barrel carburetor for this motor I'm building.
Holley, quadrajet, fomoco, edelbrock, - I'm looking please for recommendations of manufacturer & size?? I apologize for the confusion
what is your elevation of where you will be driving/ hanging out most of the time ?
I stand corrected, I was under the impression that this 390cfm was a 2bbl. (Sorry Mr. Chappie).
I'll check out your on-line catalog Jeff for this carb - and thanks again for the education.
