Go Back   IH PARTS AMERICA > Tech Forums > Axle Tech Questions
Old 04-30-2012, 01:10 PM   #1
72Hulk
72Hulk's Avatar
Member Number: 3721
Default Dana 44, how do I identify?
I have a 72 Scout II. I have posted before trying to find a d44 front. I have still been looking. I found a guy that has a Scout Dana 44 front. He had purchased it for a Jeep crawler, but didnt use it. How do I tell its a "Scout d44", and not a Dana 44 that wont work?
Thanks-
72Hulk is offline   Reply With Quote
Old 04-30-2012, 04:35 PM   #2
Scoutboy74's Avatar
Member Number: 453
Default Re: Dana 44, how do I identify?
Have him email a pic of it which you can post here. The differential must be offset to the passenger side (lhd) for prop shaft alignment. If you still have the stock spring under axle (SUA) suspension, then the spring perches must be on the bottom of the housing. These housings are commonly modified for a spring over axle (SOA) suspension which involves a cut and turn of the outer c's and relocating the perches to the top side of the housing. The measured distance from wms to wms would be good to have in your arsenal. I don't know what it is, but perhaps someone who does will see this and post up.
Old 04-30-2012, 09:07 PM   #3
Mochamike
Mochamike's Avatar
Member Number: 204
Ask for the bom number...
Then look it up by searching for Dana 44 bom....
62 Scout 80, SBC 350 on Propane, SM465/NP241/NP205 D60s on 37" Krawlers
"All Whee Drive!"
Mochamike is offline   Reply With Quote
Old 05-01-2012, 07:10 AM   #4
72Hulk
72Hulk's Avatar
Member Number: 3721
I have SUA, and will keep it that way, it is lifted 4" Rough Country lift, but dont really want it top heavy. I will post pic in a second, thanks
Old 05-01-2012, 07:17 AM   #5
72Hulk
72Hulk's Avatar
Member Number: 3721
This is the pix I have of the front Dana 44, does anybody know?
Old 05-01-2012, 07:39 AM   #6
Scoutboy74's Avatar
Member Number: 453
Its a d44 with passenger offset setup for SUA. The only question now is the width, which can't be determined in these pics.
Old 05-01-2012, 09:21 AM   #7
72Hulk
72Hulk's Avatar
Member Number: 3721
Would this definitely be from a Scout II?
Old 05-01-2012, 09:21 AM   #8
72Hulk
72Hulk's Avatar
Member Number: 3721
Was Scout the only with passenger side drop?
Old 05-01-2012, 10:02 AM   #9
Mochamike
Mochamike's Avatar
Member Number: 204
Originally Posted by 72hulk View Post
would this definitely be from a Scout II?
Nothing is definite. It's 30+ years old. Parts could have been changed/swapped, etc. Etc.
It looks like it has Scout knuckles.
But it could be from an IH pickup, which I think could be wider.
In order to be 100% sure about the housing itself is to get the bom number & look it up. It will tell you what model year vehicle that housing came from.
A tape measure will tell you the width.
was Scout the only with passenger side drop?
Yes.
From the pix it looks like its in ok shape.
However, plan on replacing lots of parts:
bearings, (outers & inners)
ring & pinion, (do the ratios match?)
u-joints
calipers (are they missing?)
rotors & pads
wheel studs? (they look missing).
All above will cost you a couple of hundred to do... (talk to Jeff at IH only).
Depending on demand/pricing in your area, I'd say it's worth around $100-$200 for that....
"All Whee Drive!"
Old 05-01-2012, 12:20 PM   #10
72Hulk
72Hulk's Avatar
Member Number: 3721
Thanks alot.
He said he has new pads, calipers, and rotors for the front. He would throw in.
Old 05-01-2012, 06:58 PM   #11
72Hulk
72Hulk's Avatar
Member Number: 3721
Here is the bom numbers
3 1 8 b5 610035 1
Old 05-01-2012, 07:03 PM   #12
72Hulk
72Hulk's Avatar
Member Number: 3721
I think it is a 78 Scout Dana 44 front
Old 05-01-2012, 08:51 PM   #13
Mochamike
Mochamike's Avatar
Member Number: 204
Yep...
how to identify a Dana / spicer axle. - binder planet forums
http://www2.Dana.com/pdf/x510-8dsd.pdf
"All Whee Drive!"
