SV AND 4 CYLINDER OILING DIAGRAMS.
Robert Kenney
Super Moderator
I will create schematic diagrams of how where and at what magnitude oil is pumped through our IH's. They will be attached in this thread. Questions and much confusion come up regularly all over the IH forms so we hope this will put them to rest.
First is only the head and rocker assembly feed.
The biggest factor that will effect flow to either bank is the cam bearings. Either from being improperly installed or from copmlete delamination of the bearing's babbitt or wear surface. Some times the bearing can spin in the block but that is rare.
  • SV OIL FLOW-CAM HEADS.pdf
