Go Back   IH PARTS AMERICA > Tech Forums > Brake Tech
Old 01-04-2012, 06:26 AM   #1
blhensley
blhensley's Avatar
Member Number: 1381
Question Scout 800A Power Brake Conversion
I want to convert my 1970 Scout 800a to power brakes to go along with the '74 Scout II axles/disc brakes I put under it. Does anyone know of a power brake booster/master cylinder setup from another vehicle that's a good swap? I really dont think the booster from a Scout II will fit the limited space available.
blhensley is offline   Reply With Quote
Old 01-04-2012, 01:37 PM   #2
FDChappie
FDChappie's Avatar
Member Number: 3742
Default Re: Scout 800A Power Brake Conversion
I've read that hydro boost is the way to go on the 80 and 800's. Iirc an astro van is a good source.
Old 01-04-2012, 03:02 PM   #3
blhensley
blhensley's Avatar
Member Number: 1381
How does the hydro boost work and what is the other vehicle besides the astro van?
Old 01-05-2012, 02:47 PM   #4
Aubrey
Member Number: 1554
Instead of vacuum boost it uses power steering pump pressure. That van setup I see most common. Diesel trucks will have it too but I'd imagine they will be quite large.
1974 Scout II, V-345A Gas 2-brl, Fed Exst Emiss Ctrl, Dual Horiz Tail Pipes, 3-Speed A727, D20, D44 3200# Locking Hub 11.75 Disc (elocker), D44 (Detroit, discs), 4.56, 19 Gal w/ Skid Plate, 105 amp 10SI, Saginaw Pwr Steer, Hvy Dty Rr Step Bumper, Dlx Ext Trim, Dlx Int Trim Blk
Aubrey is offline   Reply With Quote
Old 01-05-2012, 04:49 PM   #5
FDChappie
FDChappie's Avatar
Member Number: 3742
I've seen them on lincolns too.
