Go Back   IH PARTS AMERICA > Tech Forums > Ignition Tech
Old 07-28-2011, 03:18 PM   #1
IceFyre13th
Member Number: 3420
Default What Distributor cap and rotor needed for fuel injection kit?
Just got the fuel injection kit for my Scout II 345 but there is no distributor cap or rotor in the box. What distributor cap and rotor is needed for fuel injection kit?
And while I am asking, what is the best set of ignition wires for the same?
Thanks in advance
IceFyre13th is offline   Reply With Quote
Old 07-28-2011, 05:32 PM   #2
Craig
Craig's Avatar
Member Number: 5
Default Re: What Distributor cap and rotor needed for fuel injection kit?
Did you buy it from an IH vender? If so, contact them.
For the diy crowed there are 2 ways to. Check bills FAQ and look for mopar conversion of your stock holly dissy.
Or there is a guy in idaho that will marry a GM and IH dissy if you send him money and dissy's
Dana 60/ 14 bolt.
37" Pit bull tire
Old 07-29-2011, 09:38 AM   #3
IceFyre13th
Member Number: 3420
complete TBI fuel injection system for your IH - International Scout parts
That is the kit I have, notice in the picture the cap is on the distributor, my kit dose not have this part or the rotor in the box.
So I either have to buy one, or I got shorted and one has to be sent to me.
I posted the question here as ihonlynorths contact page said to post here as they get too many e-mails.
Old 07-29-2011, 01:01 PM   #4
Craig
Craig's Avatar
Member Number: 5
You would have to post a pic in this thread for me to see it, as it laying down with a top in the back of the pic.
It looks like a GM top. Note: the 1980 Scout and the GM cap uses a male cap vs a female cap on the dissy.
Also the GM cap stem height of the male plastic part is about 1/4" shorter then a 1980 IH cap. So I found the spark plug wires would not slip on tight. I trimmed about 1/8 of the spark plug boot off to get them to fit tight.
I did not get the setup you have, but Jeff makes all his stuff plug and play and you might not need to doing anything.
A quick call to Jeff would clear all of this up.
My dissy looks like this
I used stock 1980 wires
This might help you too.
Dana 60/ 14 bolt.
37" Pit bull tire
Old 08-01-2011, 01:38 PM   #5
IceFyre13th
Member Number: 3420
Thanks for the information, but I still need to find out what I have.
Guess I will have to call Jeff............
Old 08-02-2011, 10:21 AM   #6
IceFyre13th
Member Number: 3420
Talked to Jeff last night, the new afi kit dose not include the cap and rotor for the distributor any more. But the parts needed are for a 1975 Scout II holly distributor.
Thanks for the help again.
