Old 11-14-2010, 07:39 PM   #1
77 Traveler
Member Number: 1826
Default 1977 Traveler
For sale 1977 International Scout traveler (118 wheel base) with 94,500 miles on the odometer with so reason to believe it rolled over. It has the 345 v8 motor, t19 transmission, Dana 20 transfer case, and Dana 44 front and rear axles with 3.73 gears. The Scout is a very capable off road, hunting, or daily driver that average 16 mpg on the last two road trips. It has a removable fiber glass hard top that and tail gate. The interior and vinyl seat are in great shape considering it is 33 yrs old. I have around $7,900 invested in this vehicle, but know I will not get that for it.
New parts and work done in the last 1,500 miles
rebuilt 345 v8 stock with about 1,500 miles on it now
rebuilt with new oil pump, water pump, rod bearings, main bearings, cam bearing, cam and lifters, timing gears, piston rings, valve job.
new alternator, remanufactured starter
new distributor with petronix electronic ignition kit
new spark plugs, wires, cap, coil, and rotor
new fuel pump, fuel filter, and plastic gas tank
rebuilt carburetor, radiator, and new hoses and termostat
new superlift 4 suspension lift with all new poly bushings
new poly body mount bushings
new ranchero 9000 shocks
new front and rear brakes
reinforced front spring mounts with two steel gusset plates on each side
new windshield and seal
five new 31/10:50/r15 tires
alignment with two new tie rod ends
needs work
power steering pump works fine, but leaks
the steering gear box has a little bit of play and should be able to adjust
exhaust system is complete but old
rear latch assembly for tail gate is missing
Colorado springs, co asking $5,500 obo
77 Traveler is offline   Reply With Quote
