Old 11-23-2010, 02:32 PM   #31
reuben
reuben's Avatar
Member Number: 35
Default Re: I have a running scout
Ok, I think I will pass on them, thanks though. If I need to make bases I will use the seats I have.
another scout 2 on 1 tons
http://www.thisdysfunctional.org
http://www.norcalscouts.com
reuben is offline   Reply With Quote
Old 12-10-2010, 06:57 PM   #32
reuben
reuben's Avatar
Member Number: 35
I farted around with it for a bit today and got all the lights working. I ended up using some of the oval trailer lights for my tail lights. I just could not justify spending $85 each for new rear lenses that will probably end up broken anyways.
Old 12-12-2010, 05:28 PM   #33
reuben
reuben's Avatar
Member Number: 35
My rear bumper is just about done. I just need to clean off the splatter and paint it. It wraps around the corners and will have some spreaders bolted from the outriggers to the frame.
And this is how she sits
Old 12-27-2010, 06:19 PM   #34
JohnnyC
JohnnyC's Avatar
Member Number: 1085
Like the strut and nice welding man, your rigs coming along, keep up the good work.
John D. Colvin, USAFVET
JohnnyC is offline   Reply With Quote
Old 12-27-2010, 08:00 PM   #35
reuben
reuben's Avatar
Member Number: 35
Originally Posted by johnnyc View Post
like the strut and nice welding man, your rigs coming along, keep up the good work.
Right on, thanks
Old 09-18-2011, 07:37 PM   #36
reuben
reuben's Avatar
Member Number: 35
Been working on this trying to tie up all the loose ends. Here is the new bumper. There are 7 1/2" bolts holding it on. 3 horizontal and 4 vertical, I do not think it will get torn off in a hard pull.
Old 10-13-2011, 08:37 PM   #37
reuben
reuben's Avatar
Member Number: 35
Getting closer
I need to push the front end out a bit so the tires clear the firewall when I turn to full lock. It is easier to trim the front of the fenders then the rear of them.
Old 10-14-2011, 07:51 AM   #38
Craig
Craig's Avatar
Member Number: 5
Or add some bump stops
looks good.
Dana 60/ 14 bolt.
37" Pit bull tire
Old 10-14-2011, 06:54 PM   #39
reuben
reuben's Avatar
Member Number: 35
That is with the bumpstops. I re-did the mounts today and moved the axle 2" forward.wheel base now is 105ish
Old 02-06-2012, 10:07 PM   #40
rivera78s2
rivera78s2's Avatar
Member Number: 4336
Customs the only way to go haha great welds! I envy you
rivera78s2 is offline   Reply With Quote
Old 02-07-2012, 10:43 PM   #41
reuben
reuben's Avatar
Member Number: 35
Thank you
Old 02-12-2012, 08:39 PM   #42
reuben
reuben's Avatar
Member Number: 35
The new motor fired up, now I just need to hook up some radiator hoses and tie up a couple loose ends in the engine compartment. I dropped it off last Wednesday to have my gears installed, so it should be done tomorrow or Tuesday then it goes to the exhaust shop. My punch list is getting shorter. I think my last major task is to build a cage in it before our hollister trip next month.
Old 02-16-2012, 09:47 PM   #43
reuben
reuben's Avatar
Member Number: 35
It is at the exhaust shop, I am going to try to drive it this weekend.
Old 03-19-2012, 08:03 PM   #44
reuben
reuben's Avatar
Member Number: 35
I drove it around the house a bit. I need to figure out why my FI is acting goofy. 1 of my injectors just started leaking around the top. And it really bogs down under a load, like it has no power, it sputters and coughs if I just hammer down the pedal.
I am not running an esc or knock sensor so I jumped the wires b7 and c14, or b14 and c7 I dont remember right now. The only codes it is throwing is 12,42,43. I want to get this dang thing drivable
Old 03-19-2012, 09:50 PM   #45
Craig
Craig's Avatar
Member Number: 5
Got laptop?
Got cable?
Leaking injector not that big of a deal unless it pouring in.
I would get the numbers while running.
Post a pic of the numbers. If the temp sensor looks correct. The o2 sensor bouncing all over the place, etc.
Is the fuel close to 128?
Can you see it spraying fuel in a nice cone when you give it some gas
I might have an extra esc some where.
Dana 60/ 14 bolt.
37" Pit bull tire
