Old 01-23-2018, 11:33 PM   #196
MarkO
Member Number: 740
Default Re: 1964 Travelall and 1967 Travelette All Wheel Drive's
Why not try doing a disc brake swap for the rear as well?
It couldn't cost that much more than finding NOS brake drums or putting in a sleeve in your current drums.
MarkO is offline   Reply With Quote
Old 01-24-2018, 10:49 AM   #197
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Yeah, I won't be using OEM drums. Creating another solution that we all can live with.
Robert Kenney
Old 01-28-2018, 08:48 AM   #198
Robert Kenney
IHPA Tech Moderator
Member Number: 543
So I'm working on replacing the rear drums with a common available drum. All looks good accept for sourcing more RH thd lug nuts as I will be replacing the wheel studs. The left side are left hand thread from the factory.
My problem is the lug nut seat angle currently on the truck at all 4 corners. My lug nuts measure 108 degrees. WTF I included a drawing of mine and the common available ones. Is this normal for the big 6 International's? Everything available as far back as I can find would use 90 degree seats. I hope they are not modified. It is hard to tell from the wheel, what they are.
Robert Kenney
Old 01-28-2018, 09:43 AM   #199
FDChappie
FDChappie's Avatar
Member Number: 3742
Why not use left hand studs on both sides.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 01-28-2018, 09:53 AM   #200
Robert Kenney
IHPA Tech Moderator
Member Number: 543
The replacement drum requires a stud that is not available in LH.
Robert Kenney
Old 02-05-2018, 04:55 PM   #201
Robert Kenney
IHPA Tech Moderator
Member Number: 543
First look at a replacement drum for the big 6 RA. Have to report back after a test drive.
Robert Kenney
Old 02-05-2018, 05:47 PM   #202
MarkO
Member Number: 740
WOW! That sure is pretty.
Where did you find it and how much did it set you back?
More importantly, it appears to be an 8-lug drum you have machined to become a big 6-lug.
How did that work out?
Old 02-06-2018, 04:21 PM   #203
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Correct, Quite a bit of machining, and extra curricular activities on the first set.
Test drive will commence on this coming Sunday. I don't expect any difficulties. Will report back after the shake down.
Robert Kenney
Old 02-11-2018, 09:54 AM   #204
Robert Kenney
IHPA Tech Moderator
Member Number: 543
All buttoned up. Took her for a shake down drive. Have to say that it stops as well as any late model. Very nice pedal and low effort to bring to a quick stop. I think the hydraulics are set up to give to much proportional rear braking effort compared to the front. I might drop the rear wheel cylinder diameter by 1/8" to help that. I will wait till I drive it more before making the final decision.
One thing I will do before to much mileage is to have the drums trued. They need to be mounted to the hub and have the lug nuts torqued before trueing. The drums new out of the box were not round. One was .010" and the other was .015" bigger in diameter at 90 deg increments, when I indicated them in for machining. Probably should have done the trueing before mounting them, but I was anxious to test drive it.
Robert Kenney
Old 02-11-2018, 10:02 AM   #205
jeff campbell
Member Number: 39
Have found that to. Be soo true in the past 40 years. Always had rotors and drums trued up when installing new 1s.even in larger trucks as well. That's why most shops always had a shoe grinding/sanding machine. To sand the brake shoes to a perfect fit for the drums. Still have the machine dad had in D-ship shop! Still works to.
jeff campbell is offline   Reply With Quote
Old 02-12-2018, 07:35 AM   #206
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
We always have them trued as well. Just like you found they are never round so after pressing them on they get put on a lathe.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 02-12-2018, 08:54 AM   #207
Robert Kenney
IHPA Tech Moderator
Member Number: 543
I have some new seals on the way. Probably happen this weekend as long as the seals make it. Can repack the inner bearings too.
Robert Kenney
Old 02-18-2018, 06:14 PM   #208
Robert Kenney
IHPA Tech Moderator
Member Number: 543
All went well. Had the drum assemblies trued Saturday morning. I like driving it much more now. No more over spec thin drums. No more chasing the steering while braking hard. Nice hard smooth pedal. Definitely a good upgrade for the unobtainium rear drums.
Robert Kenney
Old 02-18-2018, 06:59 PM   #209
MarkO
Member Number: 740
So now you have new rear drums that appear to be wider than the originals.
What did you use and how did you get them to fit?
I saw one picture of the drum with some extra holes drilled for the studs. How did you do that? How much meat was left in the center of the drum with all of the extra holes drilled in the center?
I would imagine braking has greatly improved.
I know that when I am hitched to my Avion 34V tri-axle that when I step on the brakes the extra six brake drums slow the old T-all down much faster than I can stop the T-all by itself. Without those six brake drums braking the T-all has a really hard time slowing, let alone stopping, the 34V.
Old 02-18-2018, 07:59 PM   #210
Robert Kenney
IHPA Tech Moderator
Member Number: 543
I've posted what I am planning to post. All I can say is that it took a lot of time, engineering, and machining to put it together and if done incorrectly can lead to less than favorable outcomes. I can't accept the liability for posting more detail than has been posted. None of the pieces as they went into this are commercially available and need to be made.
Robert Kenney
