FDChappie
Well-known member
The second gear syncro in the Scout's t18 is going bad. Also there is lots of slop in 3rd when getting on/off the throttle, but no ugly gear noises. A rebuild kit would probably allow me to get another 40 years of use out of it, however I am tired of the non-syncro 1st gear which has caused some problems when the Scout could not pull a hill in 2nd while pulling a load.
I have a 50k mile t19 that was behind a diesel that I believe is in good shape. It needs the adapter plate between the xmission and tcase and a motor mount.
The first question I have is the t18 or t19 the better transmission?
Will the bull gear from the t18 swap over to the t19?
Will any other changes need to be made to the drive shafts, transmission cover or anything else?
