Old 06-08-2018, 10:59 AM   #1
mrscullini
Member Number: 7826
Default wheel spacers
79 sII with 4" rc lift 31x10.5 on the oem 15x6 wheels
i have some rubbing on the front springs when the tires are close to lock out. i decided to install 1.5" wheel spacers. the lug nuts locking the spacers onto the hubs are about 0.8" deep. they enage about 1/2 to 3/4 of the nut depth due to the thickness of the wall in the bore. so i guestimate it is about 8 to 12 threads. i used blue loctite on the spacer nuts.
should i be concerned the nuts do not engage more? i get a little paranoid about these things.
mrscullini is offline   Reply With Quote
Old 06-08-2018, 11:52 AM   #2
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
Default Re: wheel spacers
From what I've read, wheel spacers really aren't the way to go. You're better off adjusting the turn stop bolts on the inside of each knuckle to stop the spring rub.
Old 06-08-2018, 07:03 PM   #3
mrscullini
Member Number: 7826
Quote:
Thanks. I'll check it out. I do kinda like the wider stance.
Was thinking though, the loctite is probably useless, the bond likely breaks due to braking heat.
Old 06-11-2018, 05:35 AM   #4
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
We offer longer studs for situations like this.
Extended Front Wheel Stud Set for 1974-80' Scout II, Terra or Traveler w/ Front Disc Brakes
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 06-11-2018, 07:20 AM   #5
mrscullini
Member Number: 7826
Quote:
Originally Posted by ihpartsjeff View Post
thanks jeff. will definitely put this on the upgrade list.
