Old 05-15-2016, 06:32 PM   #1
Beluga
Member Number: 954
Default Bushing removal tool
Does anyone know where you get this tool or has anyone modified something else to work?
It's the "split washer remover"
this is for removing the rear bushing on the upper control arm of a 66 Travelall. It has the independent torsion bar suspension.
Beluga is offline   Reply With Quote
Old 05-16-2016, 09:42 AM   #2
FDChappie
FDChappie's Avatar
Member Number: 3742
Default Re: Bushing removal tool
An air chisel is the default suspension bushing removal tool around here. If you want to be a little more delicate, burn the rubber part of the bushing out with a torch and then use a hacksaw to cut most of the way through steel shell. And then a hammer and cold chisel to finish the job.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 05-16-2016, 01:45 PM   #3
Beluga
Member Number: 954
Thanks, that helps.
I used a press to push out the rubber and the inner metal sleeve already.
I wasn't sure if using a chisel would be appropriate to bang out the rest of the bushing because I am sure that doing that must mar the surface of the control arm where the bushing slides into. But this is the first time I am doing this so I don't know.
Does it cause any issues with pressing in the new bushing?
Old 05-16-2016, 02:25 PM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
If you're careful there won't be any marks, otherwise clean up the high spots with a rounded file.
Old 05-17-2016, 09:48 AM   #5
Greg R
Member Number: 527
does it cause any issues with pressing in the new bushing?
Control arm bushings are pretty tight. So yes, be as clean as possible. Being that they're removed from the non-flanged end, the 3 piece tool easily centers in the recessed area. You might substitue a machined disc from a set of drivers that can fit and press it out that way. These ain't spring bushings that are just chisled out, the front end and torsion arm concentrate a lot of force on them so anything to keep them happy is what I would do.
