Old 09-17-2015, 09:00 AM   #1
presence
presence's Avatar
Member Number: 7878
Default Jack for 1974 Scout II 4x4 L6 with 31X10.5-15 tires
Vehicle specs:
1974 International Harvester Scout II
l6 258, 4 speed manual
original drive train parts, original frame and body
31x10.5x15 tires
hey guys,
I'm kevin, and I bought my first IH car yesterday. Everything checks out mechanically (not so great cosmetically, but its not a dollhouse), but one thing is missing. A usable jack. I have the original bottle jack that came with the vehicle, but its far too short to lift the Scout high enough to remove a wheel.
What do you guys usually get for this kind of situation? I was considering just buying a silverado 1500 jack from the salvage yard just to get it done, but I don't have any experience with the challenges related to dealing with a Scout problem that requires a jack. Any pointers?
presence is offline   Reply With Quote
Old 09-17-2015, 10:04 AM   #2
Hondo
Hondo's Avatar
Member Number: 4714
Default Re: Jack for 1974 Scout II 4x4 L6 with 31X10.5-15 tires
Most people get a high lift jack, but then you have to find a place to store it. Never tried with a bottle jack, but seems it would work for changing a tire if it was under the bottom u-bolt plate of the tire your changing, maybe with a block of wood under it.
Old 09-17-2015, 10:53 AM   #3
presence
presence's Avatar
Member Number: 7878
Yeah, I would have to fab something on the exterior to make that work, and for now I just want something I can just throw into the cab somewhere to change tires...I'm not going to do any technical driving with this (at least not for now, until everything is in order) so I was hoping for something that would fit inside the thing.
Old 09-17-2015, 11:40 AM   #4
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
I would buy a small floor jack that comes in a plastic case. Easy to store yet very useful when needed. Most auto parts stores sell them including places like sears, kmart, etc.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 09-17-2015, 12:19 PM   #5
presence
presence's Avatar
Member Number: 7878
I just ended up buying a 2.25 ton jack as you suggested. No reason to suffer.
Old 09-17-2015, 01:36 PM   #6
presence
presence's Avatar
Member Number: 7878
Have you guys had trouble using these kinds of jacks on unfriendly roads? *largely shale, or very uneven?
Old 09-17-2015, 04:04 PM   #7
blue smoke
blue smoke's Avatar
Member Number: 4833
IH car
You probably are too young to remember that International had an advertisement that said anything less than a Scout is just a car
1980 Traveler
1970 Scout 800 A
1972 Travelall 6.9 powered
blue smoke is offline   Reply With Quote
Old 09-18-2015, 11:29 AM   #8
Hondo
Hondo's Avatar
Member Number: 4714
I actually mounted my hi lift on the floor in front of the back seat. Drilled a hole through the floor for the center and made a bracket that mounts to my show bar mounts for one end. About the only one that rides in my back seat is my daughters springer spaniel sirus. Backs kind of dirty, just got back from a week of camping and heading down to hollister this weekend, so it's just going to get dirty again. Just got to improvise for a jack on rough terrain, just be extra carefull about getting body parts under the truck.
http://forums.IHPartsAmerica.com/att...1&d=1442605200
Tags
jack
