Go Back   IH PARTS AMERICA > Tech Forums > Fabrication
Old 01-29-2015, 08:11 AM   #1
72Hulk
72Hulk's Avatar
Member Number: 3721
Default quick release doors?
So has anybody ever fabricated a Jeep style quick release door?
Or is the stock doors to heavy?
I take my doors off eveey summer, its quite a chore, definitely need assistance every time.
Just wondered if this was a possibility.
Thx
72Hulk is offline   Reply With Quote
Old 03-12-2015, 08:57 AM   #2
77SSII
Member Number: 1048
Default Re: quick release doors?
I would buy a set if they were available...
77SSII is offline   Reply With Quote
Old 03-12-2015, 11:09 PM   #3
Craig
Craig's Avatar
Member Number: 5
The Scout II door with everything weights in at 100lbs. Well darn close to it,.
You can get tube doors. You pull your doors with the hinges and then bolt in the tube doors. They use a leaf spring bushing as the hinge. You would have to fab up some cloth/vinyl skins to keep the mud out of the cab.
73 Scout II. 345/727 with ORD Magnum range box to NP205.
Dana 60/ 14 bolt.
37" Pit bull tire
Craig is offline   Reply With Quote
Old 03-13-2015, 04:43 AM   #4
dkminors
dkminors's Avatar
Member Number: 1337
Don't tell my wife, but I use one of those giant inflatable yoga balls to install my doors. Just need to set the air pressure to the right level and then balance them on top. They roll right in without needing help.
1975 Scout II 304 4-speed
dkminors is offline   Reply With Quote
Old 03-13-2015, 08:21 AM   #5
FDChappie
FDChappie's Avatar
Member Number: 3742
Brilliant solution!
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 05-10-2018, 08:45 AM   #6
ScoutUnlimited
Member Number: 9160
We have the same thoughts, but at the end of the day it was easier to produce both square and round tubular drop in doors for our clients.
ScoutUnlimited is offline   Reply With Quote
