Old 04-26-2018, 05:50 AM   #1
int77345
Member Number: 624
Default holley 4bbl carbs
scout II 345 manual transmission
scouts with the 345 came from the factory with stock holley 4bbl carbs correct ?
does any one know the model of carb and the jet size in that factory carb ?
Old 04-26-2018, 02:48 PM   #2
Dealbreaker74
Dealbreaker74's Avatar
Member Number: 697
Default Re: holley 4bbl carbs
4BBL Scout IIs came stock with Carter Thermoquad carbs. Holleys were on square bore 392s in the bigger trucks.
Old 04-26-2018, 02:58 PM   #3
int77345
Member Number: 624
thank you ! i didnt know that
ok amending my original topic, any one out there running a holley 4bbl on a 345 what size jets do you have ??
i picked up a holley and its jets are 57# and power valve 2.5 it feels lean to me any thoughts ?
Old 04-26-2018, 09:42 PM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
There are 100's of different Holley carbs. Give us the LIST number found on the air horn so we can look up what you've got. I'm running LIST 8007 390cfm square bore carb on my Scout's 345.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 04-27-2018, 09:10 AM   #5
int77345
Member Number: 624
same as your list sir,
this weekend in am going to try a #60 in the main jet #64 in the secondary and a 6.5 power valve
Old 04-27-2018, 08:27 PM   #6
FDChappie
FDChappie's Avatar
Member Number: 3742
Look up my thread on tuning this carb. Search 8007. It's all there.
