Old 11-01-2016, 02:21 PM   #1
Jeffsarasota
Member Number: 8450
Default Water pump pulley removal??
I have a 1978 345 . Not the big nut version. I need to remove the pulley from water pump. Do I just remove the four large phillips head screws? Or do I need a pulley puller? How do I keep the pulley from turning when I try to remove the screws ? Thx
Jeffsarasota is offline   Reply With Quote
Old 11-01-2016, 02:28 PM   #2
FDChappie
FDChappie's Avatar
Member Number: 3742
Default Re: Water pump pulley removal??
Yes on the large phillips screws.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 11-01-2016, 04:09 PM   #3
Jeffsarasota
Member Number: 8450
Thx any trick for getting pulley to not turn?😬
Old 11-01-2016, 05:04 PM   #4
Zaedster
Future Owner of IH Parts America
Member Number: 7132
Just use a air impact gun or purchase a strap wrench.
Zaedster is offline   Reply With Quote
Old 11-01-2016, 07:16 PM   #5
FDChappie
FDChappie's Avatar
Member Number: 3742
Clamp the water pump impeller in a vice and use a cordless drill with a #3 or 4 bit in it.
Old 11-01-2016, 08:46 PM   #6
Scoutboy74's Avatar
Member Number: 453
Just be careful not to bend the blades or stress the cast housing. You May find those phillips head screws are rust seized in place. Why they chose to use phillips head and not some low profile hex head is beyond me. At any rate, I've had success breaking them free by cinching around the head with vice grips. You only get about a 1/16th of a turn that way, but that's enough to free them up so that they will come out easier with a phillips driver. You just don't want to strip out those phillips slots.
Old 11-02-2016, 08:38 PM   #7
FDChappie
FDChappie's Avatar
Member Number: 3742
Good point sb, only do the vice thing if your getting a new pump.
Old 12-05-2017, 07:02 AM   #8
WillyMcG
Member Number: 8578
Question Re: Water pump pulley removal??
Does the fan simply pull off of the center shaft after removing the four bolts?
WillyMcG is offline   Reply With Quote
Old 12-05-2017, 11:01 AM   #9
Zaedster
Member Number: 7132
Yes, after the four bolt are off the fan slides off.
