Old 09-28-2009, 03:07 PM   #1
235frog
235frog's Avatar
Member Number: 257
Default Pete's Buildup '73 Scout II
Well I had someone say that I should post up with what I have done so far to my Scout in a build-up thread, so I figure I might as well get around to it.
I bought the Scout in May of 2007 from a guy who basically mislead me about a lot of things, but oh well. It was a round peg and I have been busy smashing it into a square hole. So far its been working.
This is the first picture I have of it after I hauled it home. 1973 Scout II 345, tf 727, Dana 20, Dana 44 front and rear, 4 " SUA lift, 32" BFG's. It wasn't running and didn't have a current registration soo when I went outside the following morning I had a meter maid trying to get it towed. What a wonderful start to my Monday morning. Luckily I didn't have a problem going to the dmv and registering it that same day.
And this is why.
The po apparently took a turn too wide hit a curb and caused the transfer case to snap an ear off of the tailhousing, as well as tear the rear front springer hanger off the frame.
-Pete
'73 Scout II 345/727/d20
D44, D70HD with 37s
235frog is offline   Reply With Quote
Old 09-28-2009, 03:13 PM   #2
235frog
235frog's Avatar
Member Number: 257
Default Re: Pete's Buildup '73 Scout II
First up was replacing the tailhousing and installing the transfer case. After this was done I realized that although I could drive it around, park didn't engage. (it took me a couple of years to figure out I installed a piece backwards in the tailhousing). Then since I could drive it around a little I had vacuum leaks out the wazoo and the vacuum advance didn't function, oh yeah and the carb needed a rebuild since it started pouring gas out of the secondaries (q-jet). I took it into a carb. Shop (horrible decision) who replaced the distributor and put on another q-jet.
I swapped a pertronix at the same time. Happy days! I could drive it around!
-Pete
D44, D70HD with 37s
Old 09-28-2009, 03:17 PM   #3
235frog
235frog's Avatar
Member Number: 257
Next on the list of things to do was put a 1" body lift on. At this point I thought I might as well stay SUA since a SOA conversion seemed to complicated for me. Problems with the current body mounts though.
But idiot that I was, I did it anyways.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 03:23 PM   #4
235frog
235frog's Avatar
Member Number: 257
That wasn't the worst of it though. When I started removing the carriage bolts for the 2 rear-most body mounts I had to cut away a little of the bed liner the po put in. What was underneath was horrible. He placed some sheet metal over a very rusty bed and proceeded to screw it down into the gas tank!!! I replaced the steel gas tank with a poly 19 gallon tank and I replaced all of the fuel lines at the same time.
I finished the body lift, and realized the problem with the screws later. The body lift did kill my ragjoint. So...
-Pete
D44, D70HD with 37s
Old 09-28-2009, 03:27 PM   #5
235frog
235frog's Avatar
Member Number: 257
Here's what's under the bedliner. It looked so solid before I started removing the liner.
And my favorite: the duct tape patch covered by bed liner.
Since I was busy cutting everything else out I cut some of the fenders out too.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 03:33 PM   #6
235frog
235frog's Avatar
Member Number: 257
This is after I finished trimming the fenders, still with 32"s
While I was waiting to finish cutting out the rest of the bed to replace it, Christmas came and I got some 4.56's, and aussie lockers to help out with some 35" baja claws I picked up from a friend.
regearing and adding lockers:
More info and pictures in this install thread.
gears and aussie locker install - binder planet forums
-Pete
D44, D70HD with 37s
Old 09-28-2009, 03:38 PM   #7
235frog
235frog's Avatar
Member Number: 257
Next up on the list was installing a twin stick kit from jb fab.
Simple to do, but easier when there are two people to help dealing with the t-case.
I didn't end up removing the interlock pills (?) from inside the case. I now have front 2 low, rear 2 lo, etc. The only combo I can't get is front 2 high. No biggy. So far it works well for me, except that the rear axle likes to pop out of gear when in low at the most inopportune times. The solution so far has to get a chain and an eyebolt.
here's a thread when I actually installed the twin stick conversion and has more details of what I did:
jb fabrication d-20 twin stick install - binder planet forums
-Pete
D44, D70HD with 37s
Old 09-28-2009, 03:43 PM   #8
235frog
235frog's Avatar
Member Number: 257
At some point in the Scout's history it was SOA, or at least the rear axle was. So I decided to try out the rear SOA on stock springs and the front with the 4" lift springs.
This is how it turned out.
The shocks stayed disconnected for about 8 months or so. No this was never my daily driver. And I still hadn't taken it offroad yet.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:02 PM   #9
235frog
235frog's Avatar
Member Number: 257
Next on the list was to finally get the bed re-drone. A friend agreed to help and handle the welding and I provided the dumb brute strength and did all of the prep work of grinding and cutting out the old metal. I also got to use a plasma cutter for the 1st time and that makes everything go so much faster than a sawzall and cutoff wheel on the grinder
This was my first attempt at welding and it was trying to weld 20 gage to 14 gage. It was well beyond my means to do cleanly, so I won't show off my booger welding skills
I ended up using some mid-80's GM wheel wells that were much bigger than the stock Scout ones to allow larger tires. This is the finished effort on the bed.
It took about 2 full days to get it all done. It was a huge pain, but I am so glad that I did it. The old floor was worthless.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:10 PM   #10
235frog
235frog's Avatar
Member Number: 257
Since I was going to be leaving the military (after 8.5 years) and moving I decided I better do all the things that I could to the Scout that I needed friends to help me with. I decided to do the front SOA. This took a few days and since I didn't have a garage or driveway to do it in, I went to a friends house that let me store it there for a while. I think it took about 3 days of work. It goes slower when you have to do things by yourself because everyone else is working
I followed bill-usn-1's thread SOA-the build up continues! Part 2 - binder bench
To help build my confidence. I had a professional do the welding though. It cost me like $150 or so since I had him bring a portable unit to the house and he helped me move the axle housing around to make sure I had the perches where I wanted them and to set the pinion angle/caster angle.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:19 PM   #11
235frog
235frog's Avatar
Member Number: 257
And the "finished" SOA.
After I moved I ended up taking it on its first wheeling trip. It was horrible. The steering box started leaking like a sieve and was twisting on the frame.
I welded up the fame and added a plate with a little 120v welder I bought. And rebuilt the steering box. It was just the input seal that was really leaking bad, but it became a learning experience as I had to put all those worm gear ball bearings back.
I later added a straight steer brace. It has helped immensely!
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:26 PM   #12
235frog
235frog's Avatar
Member Number: 257
At this point it was around Christmas of 2008 and no one was planning any wheeling trips. So I thought "hey I have a welder now, maybe I should fix my body mounts."
passenger side (after I ripped out the bed liner)
I found another infamous duct tape patch job.
I ended up tearing out the whole passenger side floor pan and its supports, and chopped the rocker since I could literally push my finger through it.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:34 PM   #13
235frog
235frog's Avatar
Member Number: 257
I left the doglegs intact, and replaced the rocker with 2x4 3/16's box tube. I capped the ends with some 14 gage diamond sheet metal I had left over from the rear bed.
I used 1.5" box tube 13 gage for the floor supports and for the front body mount I used 3 sections of 1" 1/8 box tube welded together.
I know there are a ton of booger welding skills here, but everything was welder way more than it needed to be, so I know it will hold up. I used 14 gage diamond sheet metal to replace the floor pans.
And the other body mounts I replaced.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:38 PM   #14
235frog
235frog's Avatar
Member Number: 257
Same thing for the driver side.
And done.
-Pete
D44, D70HD with 37s
Old 09-28-2009, 04:44 PM   #15
235frog
235frog's Avatar
Member Number: 257
And then I finally was able to take it to hollister and get dirty
After taking it through the jungle I found the rear springs were starting to get a little negative arch so I added another full length stock main leaf with the eyes cut off as well as a shorter add-a-leaf. So far it has held up well.
-Pete
D44, D70HD with 37s
