Go Back   IH PARTS AMERICA > Tech Forums > Suspension Tech
Old 08-19-2017, 11:20 AM   #1
Blasttruck
Member Number: 7854
Default front springs for 72 1210
Hi all!
Is there anyone who sells an exact fit leaf spring kit for the 1210? I see a lot of people lifting and altering but I just need to replace....also looking for an add a leaf for the rear.
Thanx as always!
Blasttruck is offline   Reply With Quote
Old 08-22-2017, 02:20 PM   #2
MedMarine64
Member Number: 6422
Thumbs up Re: front springs for 72 1210
Originally Posted by Blasttruck View Post
Hi all!
Thanx as always!
MedMarine64 here; this is what my 1210 Travelette has on it--factory supplied overload set of 4 leaves and frame mounted brackets. Adds it up to 1 ton+.
See what you can find in that line. It will ensure it being hard to bottom it out, lol. Spped bumps will jar your teeth if going too fast.
MedMarine64 is offline   Reply With Quote
Old 09-07-2017, 12:53 PM   #3
Blasttruck
Member Number: 7854
Default Re: front springs for 72 1210
thanks medmarine!! turns out they aren't as bad as I thought....I guess there was never much arch to them to begin with....now I'm in the mess of finding out the original shock specs to replace them and the bushings....
Old 09-08-2017, 07:08 PM   #4
MedMarine64
Member Number: 6422
Dodge 1 ton springs of similar year may work well.
