Go Back   IH PARTS AMERICA > Classifieds > Wanted goods!
Old 08-12-2017, 02:50 PM   #1
lastfox
Member Number: 7672
Default complete rear Dana 27 with 4.27 gears
Hi looking for a preferably complete rear Dana 27 with 4.27 gears that I can put in my project '63 scout 80 to get it driving. I'm on the central coast of California.
Thank you!
lastfox is offline   Reply With Quote
Old 08-13-2017, 11:08 AM   #2
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Default Re: complete rear Dana 27 with 4.27 gears
I have an offset D44 setup for an 80/800 with 4.27 gears.
63 S80...."Beater"....DD/Trail/Expedition rig
64 S80...."Wilma".....back on track
78 Honda CB750K
71mtnscout is offline   Reply With Quote
Old 08-15-2017, 09:55 AM   #3
ChicoComanche
Member Number: 3770
The Dana 44 Offset is the axle you want!
ChicoComanche is offline   Reply With Quote
Old 08-15-2017, 04:32 PM   #4
71mtnscout
71mtnscout's Avatar
Member Number: 1369
The only reason I'm getting rid of it is because of the T18 install with a twin stick D20 and I have a matched set of SII D44's for it.
78 Honda CB750K
Old 08-16-2017, 07:54 AM   #5
ChicoComanche
Member Number: 3770
I had a Waggy Dana 44 offset (non-tapered) narrowed up for my 1961 Scout 80. The Waggy axle is the right choice if you want to run the stock tranny and transfer case. You need to center-up correct? If so, I can see why you want to go with the scout II axles. I will probably install the Saturn overdrive unit on mine eventually. That's a nice axle you have and I'm sure someone will want it.
Old 08-16-2017, 07:57 AM   #6
ChicoComanche
Member Number: 3770
And...I have a complete Dana 27 front and rear but I'm not sure that the gears are 4:27. I'm in Chico, CA.
Old 08-16-2017, 08:15 AM   #7
lastfox
Member Number: 7672
working on a way to get it up to Santa Cruz
Old 08-16-2017, 08:52 AM   #8
ChicoComanche
Member Number: 3770
The 27 is not a good axle for anything but light off-roading.You really want to upgrade the front to a 44 as well and if you do this, go with a front disc brake axle. A 44 front will make necessary altering the perches and steering but very much worth the trouble and expense. 44s will make your 80 a tough little goat.
