Go Back   IH PARTS AMERICA > Tech Forums > Diesel Engine Tech
Old 09-04-2015, 09:29 AM   #1
robbymeyer
Member Number: 4111
Default what to inspect before buying a turbo diesel scout
Hi guys,
are there any simple things I can inspect before buying an sd33t Scout? I've heard the only real way to gauge the health of the engine is to take the head off, which I doubt anyone will let me do before paying. I'm looking for something closer to a daily driver, so I don't want to screw myself by buying a project by mistake.
robbymeyer is offline   Reply With Quote
Old 09-04-2015, 10:10 AM   #2
blue smoke
blue smoke's Avatar
Member Number: 4833
Default Re: what to inspect before buying a turbo diesel scout
Have the seller start it cold. So once it starts some smoke is normal should clear within a minute or so depending on the temp.
When it warms up look under the Scout for the road draft tube iirc it is on the driver side by the starter have the seller rev it up a little small puffs of whit smoke are ok puffing like a locomotive is bad.
Check the coolant before it gets hot making sure it is clean and not bubbling.
Overall oil leaks aren't a killer but they could indict owner neglect.
That is the bare bones basics if you have the chance run a compression test (not easy on a diesel)
I am sure others will chime in
1980 Traveler
1970 Scout 800 A
1972 Travelall 6.9 powered
blue smoke is offline   Reply With Quote
Old 09-08-2015, 11:20 AM   #3
robbymeyer
Member Number: 4111
Thanks for the advice. I checked out the truck and the engine seemed great. Unfortunately the rest of the truck wasn't quite together. Front driveshaft off, manual hubs didn't turn, one brake randomly locks, seat belts and mirrors not installed. I was looking for a daily driver instead of a project so I had to pass.
