Go Back   IH PARTS AMERICA > Tech Forums > Diesel Engine Tech
Old 10-02-2014, 07:03 PM   #1
Josh
Member Number: 7269
Default 73 Cummins Conversion Questions
I was looking to buy a Scout and do a cummins conversion, however I found a converted 73 with a 4bt. The fuel pump is the bosch rotary style. The pump is a weak link if I want to increase power. The rig is $15,000. Good body, minimal rust, frame off restoration a few years ago, 4" rancho lift, new tires, seems to run well. Both the motor and transmission are in excellent condition.
I would prefer the 4bt with a p7100, a conversion of the rotary isn't worth the trouble in my opinion and I can live with it as is... For a while.
I'd like to ask if anyone has experience with the 4bt in a Scout, rotary or p7100?
What can I expect from the performance of a stock rotary?
If you have any suggestions concerning the two?
I'm open to buying a conversion with the 4bt p7100 if anyone knows of one?
I'm open to buying a Scout (71-76) with a clean, straight, rust free body and dropping a 4bt into it... However it seems this rig will save a lot of work.
The guy I'm buying the rig from lives about 1600 miles away and isn't super at communication, so I still need to test drive and inspect, so the deal is far from complete. Ive given him a generous nonrefundable deposit to hold it for a while. Im taking the time to explore my options, search out different opportunities, perhaps find a shop I can work with if I go a different direction...
I appreciate your thoughts.
Josh
Josh is offline   Reply With Quote
Old 10-22-2014, 10:11 PM   #2
1hc72
Member Number: 991
Default Re: 73 Cummins Conversion Questions
Imho he is asking wayyyyy to much. I wouldnt pay more than 10 and that is the top. The 4bt is a good motor. I would say you can get about 80 hp out of it
19723 international 1110 travellette
4wd d44 /d60345/tf727,unkown tcase 3.73 gears
1hc72 is offline   Reply With Quote
Old 10-26-2014, 01:00 PM   #3
clhman
clhman's Avatar
Member Number: 5667
I'm in the middle of a p7100 pump 4bt conversion. Pm me with questions. There is nothing wrong with a rotary pump. They are good to at least 200hp. I'm on 4btswaps.com, you can find my thread there. I agree $15k is steep, unless it is immaculate.
1980 Scout II, Cummins 4BT diesel, NV4500 trans, NP205 Case, 3.07 Dana 44's, 32's.
clhman is offline   Reply With Quote
Tags
conversion, cummins, restoration
