Go Back   IH PARTS AMERICA > Tech Forums > Transfer Case Tech
Old 09-20-2015, 03:47 PM   #1
JAYSON
JAYSON's Avatar
Member Number: 704
Default ih np205 input spline
Looking for the spline count for the 205 input off the top of their heads?
Hayward Harvesters
74 D100 Brick injected vortec 350 7427ecm SM420 np205 D60 14Bolt
JAYSON is offline   Reply With Quote
Old 09-21-2015, 06:10 AM   #2
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: ih np205 input spline
Should be 32 spline on all shafts.
IH Parts America - Owner
(530)274-1795
Old 09-22-2015, 07:47 PM   #3
JAYSON
JAYSON's Avatar
Member Number: 704
Thanks Jeff gathering some parts to do a doubler I will see ya at the show
Hayward Harvesters
Old 02-23-2016, 04:58 PM   #4
Craig
Craig's Avatar
Member Number: 5
The output is 32 spline
the input is 10 spline.
You can replace the input with another shaft
that is what I did.
Dana 60/ 14 bolt.
37" Pit bull tire
Old 02-25-2016, 08:48 AM   #5
Mochamike
Mochamike's Avatar
Member Number: 204
You will like your doubler & wish you did it sooner.
I'm not sure about the output/set up on your truck, but I'd recommend a 241/205 over a 203/205.
Lower total (5.4:1 vs 4:1), plus an extra gear option: 2:1, 2.7:1, & 5.4:1.
62 Scout 80, SBC 350 on Propane, SM465/NP241/NP205 D60s on 37" Krawlers
"All Whee Drive!"
Mochamike is offline   Reply With Quote
