Old 01-21-2007, 06:49 PM   #1
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default 63' Scout 80
This 1963 Scout 80 is a recently completed project of ours. We started this build in late November 2006 and finished it 4 weeks later. Aside from starting with a painted body and a rebuilt engine we had to rebuild and assemble everything else from scratch. As the story goes, the owner Tom had this vehicle worked on by several other shops none of which were reliable enough to complete the project. Twice he had a shop bail out on him only to go retreive the Scout and bring it back home. When Tom came to me he was pretty "gun shy' so to speak but I assured him we would not only get his Scout back on the road, but do it in only a short few weeks and have a rig that was better than new. When Tom arrived he had the little green Scout in tow with a pick-up bed full of parts.
So here's breakdown of what was to be done:
inspect and install 152 4 cyl rebuilt engine
rebuild the t90 transmission and Dana 20 transfer case
install rebuilt Scout II Dana 44 axles with 4.27 gears and front disc brakes
install power steering
install Scout II front leaf springs and a CPT reverse shackle kit
all new wiring
reassemble remaining vehicle parts
here are pics at the begining. We had already stripped the Dana 27 axles from the Scout and the leafsprings. The bottom pic shows the freshly built rear Dana 44.
Another pic
IH Parts America - Owner
Binder Books
(530)274-1795
Old 01-21-2007, 06:52 PM   #2
ihpartsjeff
Member Number: 1
Default Re: 63' Scout 80
Here are all the parts that were brought in for us to use on the project. Unfortunately most were unusable due to being left out in the elements.
Binder Books
(530)274-1795
Old 01-21-2007, 06:59 PM   #3
ihpartsjeff
Member Number: 1
With the old suspension out of the way we started the install of the CPT reverse shackle kit using Scout II leafsprings.
Here you can see the fangs mocked up.
Binder Books
(530)274-1795
Old 01-21-2007, 07:02 PM   #4
ihpartsjeff
Member Number: 1
We rebuilt a Scout II Dana 44 front axle, equipped it with 4.27 gears and new brakes, modified it for use in a Scout 80/800, and then installed it. We also dropped in the engine (after checking it over since we didn't build it).
Binder Books
(530)274-1795
Old 01-21-2007, 07:08 PM   #5
ihpartsjeff
Member Number: 1
We installed new spring bushings in the stock rear leaf springs, hung them under the Scout with new CPT shackles, and bolted in the rear Dana 44 axle.
Binder Books
(530)274-1795
Old 01-21-2007, 07:14 PM   #6
ihpartsjeff
Member Number: 1
Next the Dana 20 transfer case and t90 transmission got completely rebuilt with new gaskets, seals, bearings, and synchros. Once the paint dried they were installed with a new clutch and transmission mounts.
Binder Books
(530)274-1795
Old 01-21-2007, 07:18 PM   #7
ihpartsjeff
Member Number: 1
The mount for the power steering box was fabbed up and box installed. A custom tierod and draglink were built using 1 ton ends.
Binder Books
(530)274-1795
Old 01-21-2007, 07:22 PM   #8
ihpartsjeff
Member Number: 1
New rear brakes and brakelines were installed along with new driveshafts.
Binder Books
(530)274-1795
Old 01-21-2007, 07:32 PM   #9
ihpartsjeff
Member Number: 1
The dash was cleaned up and installed. All new wiring was installed as well.
Binder Books
(530)274-1795
Old 01-21-2007, 07:35 PM   #10
ihpartsjeff
Member Number: 1
The engine compartment was buttoned up and a power steering pump mount fabricated.
Binder Books
(530)274-1795
Old 01-21-2007, 07:37 PM   #11
ihpartsjeff
Member Number: 1
Bilstein shocks were mounted front and rear.
Binder Books
(530)274-1795
Old 01-21-2007, 07:38 PM   #12
ihpartsjeff
Member Number: 1
The Scout nearing completion.
Binder Books
(530)274-1795
Old 01-21-2007, 07:43 PM   #13
ihpartsjeff
Member Number: 1
And heres the completed rig. Turned out quite nice especially for the short time we had with it. Wish we had more pics but towards the end we got pretty busy and thus didn't get many towards the end.
Binder Books
(530)274-1795
Old 03-26-2007, 05:59 PM   #14
shane
Member Number: 152
I didnt catch what kind of wiring kit you used. Was it a premade kit?
shane is offline   Reply With Quote
Old 03-27-2007, 05:42 AM   #15
ihpartsjeff
Member Number: 1
We use/sell kwikwire wiring kits. This one was an 8 circuit model. Great quality with a great price.
Binder Books
(530)274-1795
