Go Back   IH PARTS AMERICA > Tech Forums > Axle Tech Questions
Old 11-28-2015, 12:19 PM   #1
Panaflax
Member Number: 4251
Default Dana 27 Parts Hard to Come By
Does anyone have any information on where I could get a ring and pinion set for my rear Dana 27 axle? It's going on my 61 Scout 80.
I opened up the cover and it spit out a few teeth. There's a used set on ebay right now for 190$, but the pinion has at least one chipped tooth.
Worst case, could I borrow the parts out of the front axle? I just want to get rolling again...
'61 Scout 80
Panaflax is offline   Reply With Quote
Old 11-28-2015, 03:52 PM   #2
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: Dana 27 Parts Hard to Come By
What gear ratio? I have a 4.27 fa that I won't need the r&p out of.
Robert Kenney
Old 11-29-2015, 10:39 AM   #3
Panaflax
Member Number: 4251
It's 4.27 (47/11). Would you part with it?
'61 Scout 80
Old 11-30-2015, 06:56 AM   #4
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Pulled the cover off and while it was sitting outside some moisture must have gotten inside. Lots of surface corrosion. I won't bother digging any deeper. There will be pitting for sure. Sorry .
Robert Kenney
Old 12-02-2015, 06:26 AM   #5
Robert Kenney
IHPA Tech Moderator
Member Number: 543
After some digging I see that the 27 and 30 Dana's share the same ring gear od 7.120. Any chance that the r&p are interchangeable?
Robert Kenney
Tags
dana 27, scout 80
