Old 10-23-2014, 07:45 AM   #76
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: IH Parts Americas 1-Ton Travelall
Originally Posted by tonka toy View Post
Jeff, I'm looking into upgrading to the 14 bolt rear under my 72. From what I've heard, it's about as bolt in as can be with the GM 52" springs. Is this truly an afternoon parts swap fest, or is there some modification, fab or welding required? I don't want to assume its this easy and then have my truck down for a month in my garage because there's a really important, time consuming step involved.
Also, I'm still interested in a pair of those front spring mounts for the front springs. My l/f is bent and the truck doesn't sit right because of it.
Ps: late model GM tahoe/suburban running boards fit nicely!
I don't know if I'd call it an afternoon job. I did have to replace the spring perch's as they were not in the right location. Also when used in conjunction with GM springs the springs had to have the bushings replaced with IH spring bushings so that the same hardware could be used. Also with the spring perch's they need to be the kind we sell with the three centerpin holes as the axle does need to get moved back an inch to look correct in the wheel wells. New ubolts are needed as GM 14bolt rear ends have larger axle tubes than a Dana 60. I didn't reuse any of the IH ubolts or plates so custom shock mounts had to be fabricated.
Still working on those front plates. I apologize that I haven't gotten to it yet. It's still on my to do list.
Edit - front plates are now available - CPT - Crawler Proven Technology GM spring hanger to IH pickup or Travelall - IH Parts America
IH Parts America - Owner
Binder Books
(530)274-1795
Old 10-23-2014, 02:49 PM   #77
Tonka Toy
Tonka Toy's Avatar
Member Number: 635
Sounds like you guys have a possible new product here, a 14 bolt conversion kit. what about the driveshaft? Will it be long enough and what about the u-joint?
Procrastination is your friend, because if you run out of projects, you die.
My 76 Scout 2/Dodge 360 repower pictures here: http://s48.photobucket.com/albums/f2...wer%20Project/
72 1110 Travel-All "for the wife", family outing rig.
Tonka Toy is offline   Reply With Quote
Old 10-23-2014, 04:04 PM   #78
ihpartsjeff
Member Number: 1
sounds like you guys have a possible new product here, a 14 bolt conversion kit. what about the driveshaft? Will it be long enough and what about the u-joint?
Since I did a custom transmission/transfer case conversion at the same time I don't really have any feedback on driveshaft length but fairly confident the ujoint will need to be changed.
Binder Books
(530)274-1795
Old 10-27-2014, 09:43 AM   #79
JAYSON
JAYSON's Avatar
Member Number: 704
Hey Jeff what was that a dodge d60? And what degree shims did you end up using?
Hayward Harvesters
74 D100 Brick injected vortec 350 7427ecm SM420 np205 D60 14Bolt
JAYSON is offline   Reply With Quote
Old 10-27-2014, 11:16 AM   #80
ihpartsjeff
Member Number: 1
Originally Posted by jayson View Post
hey Jeff what was that a dodge d60? And what degree shims did you end up using?
The d60 is from a GM truck. If memory serves me correct I believe they were 8 degree shims.
Binder Books
(530)274-1795
Old 10-27-2014, 05:50 PM   #81
JAYSON
JAYSON's Avatar
Member Number: 704
Cool thanks Jeff I take it you matched the IH spring perch width to the GM axle when ya changed the shackles? And im looking for a 2wd power steering box cradle to do a cross over steering on the d series.
Hayward Harvesters
Old 10-28-2014, 06:14 AM   #82
ihpartsjeff
Member Number: 1
cool thanks Jeff I take it you matched the IH spring perch width to the GM axle when ya changed the shackles? And im looking for a 2wd power steering box cradle to do a cross over steering on the d series.
The GM axle matched the IH spring perch width so that part of the install was easy and required no changes.
Binder Books
(530)274-1795
Old 11-20-2014, 11:50 AM   #83
Scout1980
Member Number: 7359
Great build.
Would that air suspension also fit under a Scout II?
Was it a standard kit?
Michael
Scout1980 is offline   Reply With Quote
Old 11-28-2014, 12:10 PM   #84
ihpartsjeff
Member Number: 1
Originally Posted by scout1980 View Post
great build.
Michael
I don't recall which kit I used but something similar could be used on a Scout. Just have to measure and do some researching.
Binder Books
(530)274-1795
Old 01-26-2015, 09:57 PM   #85
clhman
clhman's Avatar
Member Number: 5667
Jeff,
can you comment on your overall impression of the sound deadening you did? It looks like it's been a couple of years now. Are you happy with it? Any regrets? Did it make a huge difference? I just finished my cummins swap in my Scout and it's loud! I need to come up with a plan. The lizard skin looks awesome but spendy. Would you do it same if you did it again? Just looking for a little advice / wisdom.
Thanks for all your help. Everything I've bought from you has worked out great!
1980 Scout II, Cummins 4BT diesel, NV4500 trans, NP205 Case, 3.07 Dana 44's, 32's.
clhman is offline   Reply With Quote
Old 01-27-2015, 08:17 AM   #86
ihpartsjeff
Member Number: 1
Originally Posted by clhman View Post
Jeff,
I'm very happy with the sound deadening and low noise out of this vehicle. We use lizard skin on almost all our customer builds everywhere we can access to spray it(inside doors and fenders, door panels, hardtop, etc). Together with the dynamat and carpeting with the mass backing it is one cozy ride. The other benefit is how little the a/c has to work on a very hot day. I'm sure it will help with the noise levels in your Scout with the cummins but as to how much it will help is something I can't answer.
Binder Books
(530)274-1795
Old 01-27-2015, 01:26 PM   #87
clhman
clhman's Avatar
Member Number: 5667
Thanks. I will probably follow suit and replicate your install then. This is my forever vehicle and I want it to be comfortable on a long drive.
Old 01-29-2015, 04:58 AM   #88
Scout1980
Member Number: 7359
Well I would appreciate advise on wich of type and brand of air bags to use.
Was thinking of building the hydraulic load level system of a mercedes under, but this seems to be an easier sollution. And more for a heavy duty application.
Old 01-29-2015, 08:29 AM   #89
ihpartsjeff
Member Number: 1
well I would appreciate advise on wich of type and brand of air bags to use.
As I previously mentioned you just need to do some researching. Airride or firestone both make many applications of bags. Just need to do some measuring to see what all you can fit.
Binder Books
(530)274-1795
Old 11-19-2015, 04:47 AM   #90
Tonka Toy
Tonka Toy's Avatar
Member Number: 635
Quick question about your front springs. It appears to me that the 4" lift springs gives you that nose high look. If you wanted to level it up by dropping the nose, would your recommend stock GM spring height? And would you still get decent flex with a 33" tire up there? (that's what I plan on running) all of this assuming that I'm using the GM d44 axle and your new front spring mounts.
Thanks!
Jeff
