Old 04-01-2009, 12:40 PM   #16
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: 63' Scout 80
After two years this little Scout came back to us for some more upgrades. When it left it had a half cab top and since then the owner had a full travel top installed.
First up on the Scout was having a spray on liner applied to both the hard top and front cab area. We called in Brian at rockliner coatings and had him spray in a nice thick coat of vortex liner.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 04-01-2009, 01:09 PM   #17
ihpartsjeff
Member Number: 1
A basic stereo and speakers were installed to make the long trips to death valley that Tom the owner plans a little more pleasurable.
Darren fabricated a custom fuel tank for the Scout that bolts in behind the rear axle.
Inside the tank a baffle was installed along with the lines for the fuel filler and vents.
So that the tank can properly ventilate without passing gas fumes a charcoal canister was installed under the quarter panel and a shield to keep dirt/rocks away was added. A custom fuel filler neck and main vent was fabricated next.
The fuel filler neck and vent line had to go thru the frame so a hole was bored and sleeved for both lines.
With the hole cut in the quarter panel for the fuel filler it actually looks nearly like a factory install.
Binder Books
(530)274-1795
Old 04-01-2009, 01:43 PM   #18
ihpartsjeff
Member Number: 1
With mock up of the fuel tank complete it was removed and finish welded.
Once tested for leaks the tank was painted and reinstalled.
With the tank completed we moved next onto the steering. One day as we were moving the Scout around the yard under no power the lower steering column joint was trying to pop out of the lower 'bell joint'. As a major safety issue we decided to modify the steering column with a borgeson kit that we put together.
The outer steering column itself was cut down, sleeved and welded back together.
The inner column was cut down and a collar was machined to hold the lower bearing into place.
Next a 3/4" dd was machined into the shaft and a borgeson universal joint was installed.
Binder Books
(530)274-1795
Old 04-01-2009, 01:54 PM   #19
ihpartsjeff
Member Number: 1
A steering wheel adapter and a smaller more stylish steering wheel was installed.
A firewall mount was purchased and slightly modified to hold the lower column in place.
With another borgeson steering joint on the steering box and a collapsible steering shaft the column was now complete.
With a set of bcb gas tank flanges we were able to install a matching pair of modern style gas caps.
Binder Books
(530)274-1795
Old 04-01-2009, 04:31 PM   #20
Michael Dimock
IH Parts America Sales Assoc.
Michael Dimock's Avatar
Member Number: 581
Dang, nice to see an 80 build coming from you guys! This Scout is a nice one and I can see that someone keeps it on the road driving. love the original dash with all it's faded glory!
Workin' at IHPA
Old 04-02-2009, 04:33 PM   #21
Matt Main
Member Number: 446
That thing is getting more of the royal treatment! Looks great.
Jeff, do you offer that steering wheel adapter? I didint see it on the website. Id like to ditch my stock wheel and go to something a bit smaller. Can you post up the part number?
Thanks! Great work, I really like the gray vortex liner
Matt Main is offline   Reply With Quote
Old 04-03-2009, 07:53 AM   #22
ihpartsjeff
Member Number: 1
Originally Posted by Matt main View Post
that thing is getting more of the royal treatment! Looks great.
The steering wheel adapter costs $33.40. Its not listed online so you will have to call if you want to order.
Binder Books
(530)274-1795
Old 05-19-2009, 10:33 AM   #23
ihpartsjeff
Member Number: 1
Here's a few pics from when the owner Tom recently took the Scout on a trip thru death valley.
Binder Books
(530)274-1795
Old 05-19-2009, 11:15 AM   #24
Michael Dimock
Member Number: 581
Good to see the ol' Scout in action! Great job Jeff! I'm sure the new owner is very happy.
Workin' at IHPA
Old 05-25-2009, 07:05 AM   #25
zpi28
Member Number: 1102
The Scout looks great. Thats some nice work you done there.
1962 IH Scout 80, 46K miles.
zpi28 is offline   Reply With Quote
Old 06-18-2009, 10:11 AM   #26
stu simpson
Member Number: 684
Are you considering offering the aux fuel cell for general sale? What is its capacity?
stu simpson is offline   Reply With Quote
Old 06-19-2009, 06:49 AM   #27
ihpartsjeff
Member Number: 1
Originally Posted by stu simpson View Post
are you considering offering the aux fuel cell for general sale? What is its capacity?
We do plan on offering this tank set up in the future but it will not be until sometime next year. Currently all new development parts are on hold until we get our new facility up and running.
Capacity on the tank was approximately 18 gallons.
Binder Books
(530)274-1795
Old 06-19-2009, 11:24 PM   #28
Tiny Yokum
Tiny Yokum's Avatar
Member Number: 669
Great save !
IH propane 152
HVACR Specialist
Tiny Yokum is offline   Reply With Quote
Old 01-04-2011, 10:53 PM   #29
kingkonger708
Member Number: 1745
Why didn't you mount the front reverse shackles farther forward? I thought moving them forward would help approach angles and ride quality.
Wouldn't happen to have the steering wheel that you removed? Mine is cracked really bad.
kingkonger708 is offline   Reply With Quote
Old 01-05-2011, 08:12 AM   #30
ihpartsjeff
Member Number: 1
Originally Posted by kingkonger708 View Post
why didn't you mount the front reverse shackles farther forward? I thought moving them forward would help approach angles and ride quality.
So that the front tires don't hit the front of the fender and to make room for the tierod and draglink. Yes moving them farther forward helps approach angle except this is not a rock crawler and doesn't need that.
Not sure what happened to the steering wheel.
Binder Books
(530)274-1795
