Go Back   IH PARTS AMERICA > IH Parts America Area > IH Parts America Build-Ups
Old 05-14-2008, 03:00 PM   #1
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Scout II SOA & R/S in 24 Hours
Yes you read that right. A complete spring over axle conversion and reverse shackle set-up was installed on one of my best buddies Scout II in roughly 24 hours this last Saturday. This lift normally takes either Darren or myself roughly 70 hours to perform from start to finish but with highly skilled and experienced guys like Darren, Chad, Mike, and myself all working together with no interruptions we managed to make it happen in roughly one day. Because of the fast pace not too many pictures were taken but from time to time I was able to stop to take in the moment.
To make the wrench-a-thon go as smoothly and quickly as possible we did have the front axle ready to go which was the old front axle from pd's build. The knuckles on the axle were already turned and a basic hysteer kit already installed. Mike and I the week before disassembled the front axle for inspection and regeared it to 4.10 to match the rear axle thats already in Mike's Scout. With the ARB thats in this front axle and detroit locker thats already in the rear Mike should be able to take his Scout just about anywhere.
So we begin with a before shot of the Scout with Mike. Notice the height at which the hood is to his shoulder.
And more before shots. The Scout at the time was running small 28.5" tires with stock springs and mild shackle lift.
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 05-14-2008, 03:06 PM   #2
ihpartsjeff
Member Number: 1
Default Re: Scout II SOA & R/S in 24 Hours
With the Scout pulled into the shop disassembly began. We started the tear down Friday at 5:30 pm and by 7:00 pm the Scout was all stripped.
Jeff Ismail
Binder Books
(530)274-1795
Old 05-14-2008, 03:14 PM   #3
ihpartsjeff
Member Number: 1
The following morning we started work at 8:00 am. We started with the rear suspension first. I started drilling for the rear swaybar and prepping the bumpstop mounts while Darren followed behind me welding everything up. Chad prepped all the leaf springs with new bushings while Mike cleaned and painted all the parts.
A little after 11:00 and were crusing along. Rear axle is in with only the perch's needing welding.
By noon the rear suspension was done.
Jeff Ismail
Binder Books
(530)274-1795
Old 05-14-2008, 03:27 PM   #4
ihpartsjeff
Member Number: 1
All the front suspension brackets were ground off and the frame sanded down smooth.
The reverse shackle fangs were tacked into place, springs bolted in, and axle hung.
Darren starts the long task of welding everything together.
Chad stands by in case of fire.
Mike doing some final painting.
Not sure what both Chad and Mike were doing but I thought this picture would look cool.
Jeff Ismail
Binder Books
(530)274-1795
Old 05-14-2008, 04:07 PM   #5
ihpartsjeff
Member Number: 1
By 7:00 pm we drove the Scout out of the shop. I happened to have a suitable temporary driveshaft in the driveline pile that could safely take Mike back and forth to work until the new rear cv driveshaft and long travel front driveshaft show up. We also installed a borgeson steering kit since the old rag joint needed replacing.
With the new lift and 35" tires Mike's shoulder is now dead even with the hood.
And last pics on Monday when Mike showed up with his new tires and wheels.
Jeff Ismail
Binder Books
(530)274-1795
Old 05-20-2008, 03:00 PM   #6
69scout
Member Number: 26
Nice work. I say put the chrome back on. That thing is sharp...good job fellas.
69scout is offline   Reply With Quote
Old 06-09-2008, 03:18 PM   #7
StoutScout
Member Number: 474
Are those the factory springs?
StoutScout is offline   Reply With Quote
Old 06-09-2008, 07:33 PM   #8
ihpartsjeff
Member Number: 1
Yes with the exception of the rears which had one additional stock leaf added to it.
Jeff Ismail
Binder Books
(530)274-1795
Old 06-10-2008, 06:28 AM   #9
ihpartschad
IHPA General Manager
ihpartschad's Avatar
Member Number: 3
Quote:
Originally Posted by ihpartsjeff View Post
yes with the exception of the rears which had one additional stock leaf added to it.
Also this was a xlc Scout so it had the factory "overload" spring on it, I took that out when I put this leaf pack together.
Chad Maycroft
IH Parts America[/B][/SIZE]
CPT Crawler Proven Technology
ihpartschad is offline   Reply With Quote
