Old 08-27-2012, 11:28 AM   #241
Son_of_Tydeus
Member Number: 4901
Default Re: Holley 22XX Series Carb Stuff
Originally Posted by 1975ih200 View Post
are you referring to the two throttle return springs?
If so, you can go back one page to page 16 of this thread, post #238, which has two photos of the throttle return springs.
One spring should be larger diameter than the other, the small spring goes inside the larger spring for redundancy in case one spring breaks.
Thanks for the information, and post #238 was just what I needed. But when I attached both springs to the throttle, it was under so much tension that it wouldn't return at all. Is there a way to adjust that somehow? When I attached just one of the springs to see if I could get it running after the re-build, everything seemed to be working fine. But I would rather not just have that one spring on there if two are really needed.
Son_of_Tydeus is offline   Reply With Quote
Old 08-28-2012, 09:59 AM   #242
Scoutboy74's Avatar
Member Number: 453
One or both of your springs likely has too stiff of a spring rate. Ideally, the redundancy of one spring inside another is a worthwhile safety measure, but a solo spring in superb condition will get the job done.
Old 09-04-2012, 06:22 AM   #243
nitrodan70
Member Number: 4938
I need a pump shot needle for my 2210. Its not even there! Where can I get one?
nitrodan70 is offline   Reply With Quote
Old 12-28-2015, 03:53 PM   #244
JamesL
JamesL's Avatar
Member Number: 8049
Greetings from texas.... Working on a 75 Scout II with a 345, Holley 2210. Looking for the vacuum idle dash pot... Anyone know where I might find one? Picture attached...thanks for any help... Jamesl
JamesL is offline   Reply With Quote
Old 12-28-2015, 04:26 PM   #245
FDChappie
FDChappie's Avatar
Member Number: 3742
You don't really need that, unless some some smog check person says you do.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 12-28-2015, 04:39 PM   #246
JamesL
JamesL's Avatar
Member Number: 8049
Thanks for the info fdchappie (and the quick reply!)... I was rebuilding the carb and found the diaphragm blown...I'll leave it off and plug the line...cheers!
Old 08-28-2016, 12:47 PM   #247
Red
Member Number: 8326
I have a 1973 IH 1010 v8 pick up truck with 2210c Holley carb. I'm mid-rebuild on it. I have a question about a throttle solenoid dashpot.
When I purchased my float from carburetor specialists, the sales guy mentioned that my carb requires a throttle solenoid dashpot and so I purchased it without doing much research because he said that was the last one in stock. When I received the part, I realized that my carb did not even have this part on it at all. I have no idea where I'd even plug in the solenoid valve to. Anyway, do I need this part for my carb re-build or should I try returning it?
Thanks for your advice!
Red is offline   Reply With Quote
Old 08-28-2016, 06:23 PM   #248
Scoutboy74's Avatar
Member Number: 453
Sounds like he could sell a ketchup popsickle to an eskimo. You don't need it.
Old 08-29-2016, 11:29 AM   #249
Red
Member Number: 8326
Haha! Got it, thanks scoutboy74.
