Old 07-28-2012, 11:18 AM   #61
Scooter
Scooter's Avatar
Member Number: 917
Default Re: I have a running scout
Cool thanks for posting the dash area photo. Are you going to be able to use the e-brake handle in the stock location?
With the added gussets marked in yellow should do just fine. If you really want to make it safe, maybe one more vertical piece center of windshield from top horizontal tube down to dash horizontal tube. Maybe have it be removable for when you're not trail riding. I suggest this due to the fact that my windshield ended up colapsing flat down to the dash and steering wheel. Granted, what you have there already should do fine, but for the piece of mind.
What size tube ya using? Dom?
The fleet
72 Scout II = SOLD
Old 07-28-2012, 04:14 PM   #62
reuben
reuben's Avatar
Member Number: 35
There is no parking brake, and it is all 1.20 wall 1 3/4 dom. I am debating puting some v bars in the windshield. I will have tabs to the windshield to stop it from shaking around since there will never be a top on it.
another scout 2 on 1 tons
http://www.thisdysfunctional.org
http://www.norcalscouts.com
reuben is offline   Reply With Quote
Old 07-29-2012, 07:33 PM   #63
reuben
reuben's Avatar
Member Number: 35
I went and picked up a tb of of a sbc today and knock sensor and esc. The ruck fired up and runs pretty good. The idle was surging a bit until it went warmed up. It still has a slight stumble and backfire if I smashed the throttle. But is a night and day differance over the bbc tb and trying to bypass the knock sensor.
Old 08-09-2012, 07:41 PM   #64
reuben
reuben's Avatar
Member Number: 35
This dang cage kick my butt taking it out to get it 100% welded. To get it out I had to take off the windshield frame and go out over the hood. It was a tough job by myself. As I was sliding it off the front off the Scout it went faster then I thought and the back leg caught my foot. I ended up ass or teakettle , luckily I stayed on the hood instead of falling all the way to the ground.
Old 08-09-2012, 09:36 PM   #65
Scooter
Scooter's Avatar
Member Number: 917
Looks good. I can totaly relate to pulling the cage out by your self. I just pulled mine out last Friday, so I can do some floor repair on the driver side. I have some what of an advantage of having an over head electric hoist here in my shop space. Just used it to lift up and out through the tail gate. Makes me wish the ceiling in here was 3 to 5 feet higher.
One thing I notice, since you're at it and have the cage out. Possibly one more gusset. From the center vertical piece to the rear. Kinda following the lines of the ones going up towards the lift gate. Maybe from the mounting foot diangonaly up toward the back. If that makes sense. Not sure if that be overkill or not, but it looks to be a long tube run with no triangulated support below it. Ok I'll zip it for now. Keep up the good work inspires me to re-design mine since I have my cage out
The fleet
72 Scout II = SOLD
Old 09-13-2012, 02:22 PM   #66
reuben
reuben's Avatar
Member Number: 35
Babies getting new shoes
Old 09-13-2012, 02:57 PM   #67
Craig
Craig's Avatar
Member Number: 5
Whats the inside diameter the blue pipe? 16" or 17" figured they don't make 16.5 pipe.
Looks easy to get them out, guess you get to do a hula dance to get them back in.
Dana 60/ 14 bolt.
37" Pit bull tire
Old 09-13-2012, 05:42 PM   #68
reuben
reuben's Avatar
Member Number: 35
Originally Posted by Craig View Post
whats the inside diameter the blue pipe? 16" or 17" figured they don't make 16.5 pipe.
I am not sure of the diameter, they came from trailready. I bought them used off a guy in lodi. Putting them back in was easy, I put a small ratchet strap around them to egg, then stood it up and blocked it so it would not roll. Then picked up the tire and threw it down on it.
I found some 38 sx's on craigslist that was a screaming deal
Old 10-17-2012, 03:57 PM   #69
reuben
reuben's Avatar
Member Number: 35
I boosted the pressure in the regulator on my TBI and it seems to be running a bit better, but I was having cooling issues with the radiator I had in it. So I bought an aluminum one from the hot rod shop that he said would have no problem keeping the 400 cool, but it needs a shroud. So the last couple days have been building a cradle mount for the rad and a shroud. I hope to have some time off this weekend to finish it up
Old 10-18-2012, 08:44 AM   #70
Craig
Craig's Avatar
Member Number: 5
Post a log file
Dana 60/ 14 bolt.
37" Pit bull tire
Old 12-02-2012, 01:01 PM   #71
reuben
reuben's Avatar
Member Number: 35
The Scout runs like a raped ape, I got tired of dealing with the TBI so I took it all out yesterday morning and threw a q-jet and hei in it. I think I am going to sell all the TBI stuff to make a little money back on it.
Old 03-18-2017, 08:53 PM   #72
reuben
reuben's Avatar
Member Number: 35
I forgot I had this build here. I was hot ridding around and getting my rpms a bit higher then she could take. That small block 400 is toast. I picked up a TBI 350 to put in it as soon as the buggy is done.
