Old 11-05-2016, 08:46 AM   #31
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Default Re: An Expedition Scout
The hard work is done on the "poormans" lift now and I'm pleased with the results....
Before
And after
The frame plates need to be trimmed and finished welded but are welded to the factory brackets on the inside. If I were to do this again I would move the new mounting location 3/8" forward, or rearward depending on the location, to push the spring out a little more for more shackle angle, especially for the rear. I expect the rear shackle angle to be better when done cause there isnt any load on the rear right now and there will be gear in the bed when used. I replaced the rear springs with ones that I had that were just in better condition and had a little more arch to them....thus the slight "stink-bug" stance.
I also installed 1.5" wheel spacers on the rear since the waggy 44 was a narrow track unit.
63 S80...."Beater"....
78 Honda CB750K
11 Ranger S/C 2wd
71mtnscout is offline   Reply With Quote
Old 12-09-2016, 04:35 PM   #32
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Beater had a new noise since the lift...a sorta song. Turns out the e-brake cable is rubbing on driveshaft and causing the "song". So I flipped the pull rod to the bottom of the swing bracket and made a tether out of steel rod to keep the cable away from the driveshaft. It does what its designed to and the brake works fine.
1 noise down 27 to go.......
78 Honda CB750K
11 Ranger S/C 2wd
Old 01-26-2017, 09:53 PM   #33
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Now that winter is here a few things needed fixin. First up was the leaky exhaust system. A little cut and splice along with a new flange gasket, and adding another hanger later. It's amazing how much quieter it is now, I still get a wiff now and then but I still have some holes to fix. The stock heater seems to work pretty good but I need to add the heat valve and control cable to be able to shut the water off and on from inside the cab. The windshield hinge leaks like a sieve in the rain and I haven't got to it yet.
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-05-2017, 11:50 AM   #34
71mtnscout
71mtnscout's Avatar
Member Number: 1369
It has always "marked" its spot, but has been a bit excessive lately. It turns out that my tcase has alot of slop in the yokes. I was hoping to do a reseal but it really should get rebuilt. So I will be pulling the trans/tcase out of my 64 which is nice and tight and has minimal leakage and throw them in to keep him a dd. My intent is to rebuild the combo and put them back in this summer.
Oh boy!!
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-08-2017, 11:49 AM   #35
71mtnscout
71mtnscout's Avatar
Member Number: 1369
I got home early yesterday and started prepping the 64 to pull the trans/tcase to go in beater. Pulled the top cover on the t90 and the inside looks to be in pretty good condition, full of oil and no chipped teeth are evident.
Since I don't have a hoist at home it has to come out the bottom and I have to lift the Scout high enough to drag them out from under it, so the shift levers have to come off. I wanted to keep anything from getting inside the trans so I made an abs plate to bolt in place of the shift tower to keep it sealed up during the job. Other than draining fluids and pulling the front driveshaft out, it's ready to pull.
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-14-2017, 06:33 PM   #36
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Found a rental yard that has a small hoist for $25.00 a day that comes apart into 6 pieces for easy transport, so I got busy today and prepped and pulled the trans/tcase out of beater and wilma. Beaters stuff is on a roll cart now and will be torn down for rebuilding later. The swap units are on the hoist ready for install in the morning, I ran out of light and energy. I did swap the t/o bearing from the 64, beaters was chattering and it was just plumb wore out. The clutch isn't to bad looks to have about another year left on it...I will have to start saving for a new one.
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-15-2017, 01:23 PM   #37
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Awwww crap!!
Somehow the pilot bearing came loose and is wedged behind the friction plate. No big deal really except that I dont have the alignment tool for a 4cyl, got one on the way and will have it done before the weekend I think.
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-23-2017, 04:31 PM   #38
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Done, back together and it moves under its own power again. I have to say it's odd to not hear the the "I'm worn out" noises from the trans/tcase/clutch anymore, I even got a $14.99 seat cover from walmart!!
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-26-2017, 02:59 PM   #39
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Getting it ready for I.h.w.r. In April, got my ftm-350 ham radio mounted and working with a cheapo mag-mount antenna for now. I will have to save some pennies and get a good antenna soon. I also fixed my cup holders today they work great on a soda size can but the cup was so tall the larger travel cups didn't reach the bottom so I cut them down an inch or so. I need to move some cables and switches around so they don't interfere with the giant travel cup that I use.
78 Honda CB750K
11 Ranger S/C 2wd
Old 03-28-2017, 11:32 AM   #40
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Tackled the doors today, they were just barely workable. The windows didn't operate very well and I don't have a key for the doors so I ordered a set of locks from IH parts and today they came in. Changed the locks out and now I can actually lock it if I need to...wohoo! I also took everything apart and cleaned and lubed it all and now my windows aren't perfect but they work much better now. I still need to replace the window track stuff since there isn't anything in the front one and the rears are cracked and falling apart. I remember reading about using velcro in the tracks, maybe I'll go that way. Either way my doors are operating pretty good now for a 54 year old truck.
78 Honda CB750K
11 Ranger S/C 2wd
Old 04-03-2017, 03:57 PM   #41
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Took both doors apart and pulled the windows out and did 1" velcro hook on the front track, the rear track was still intact so I lubed it and left it alone. I will never put door window felts on beater so I used the cloth side of the velcro on the outer door sill to stop the widow frame to door rattle when the windows are down. Added some strategic rubber pads to the glove box door to stop that rattle, all in all it's getting quieter while driving...still can't hear a radio at highway speeds, but below 55 mph you can.
The engine has always been "piston slap" noisy for as long as I've had it but it runs great and has good compression and oil pressure. So while out on a test drive today I was climbing this hill in third and when I punched it pinged. When I got home I decided to check timing.....I guess I never checked it when I got it. It was timed at 12* btdc, what a dolt I am, I reset the timing to 0 and went for a drive...what a difference!!! The engine is sooo much quieter and has more pull on the top end too, can't believe I didn't check it! the rattles are slowly being resolved and it's driving better and better, its becoming a solid driver...now if I can stop the body rattles...
78 Honda CB750K
11 Ranger S/C 2wd
Old 04-10-2017, 01:45 PM   #42
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Added weatherproof storage in the bed today. I was going to do 2 "fat" .50 cans on each side, and May still go to that, but I got such a great deal on theses standard .50 cal boxes I had to buy them. I didn't want to get into the main bed storage area and this is the what I finally came up with to get 3 on each side and still be able to operate them easily with the bed packed.
78 Honda CB750K
11 Ranger S/C 2wd
Old 04-11-2017, 05:01 PM   #43
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Modified the existing steering stabilizer mounts to accept a stock 60's era cj-6 unit, there cheap and available over the counter most of the time. Drives much better now, doesn't wander around as much at highway speeds. The one that was on it had no resistance at all anymore and was doing nothing.
78 Honda CB750K
11 Ranger S/C 2wd
Old 04-12-2017, 03:46 PM   #44
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Started the loading of the needed gear today. Went to 4 wheel parts and picked up a mount for my hi lift and got it mounted. I picked up a nutsert tool...man this thing makes using nutserts a breeze!! I need to work on a spare tire and fuel can mount.
78 Honda CB750K
11 Ranger S/C 2wd
Old 04-16-2017, 12:51 PM   #45
71mtnscout
71mtnscout's Avatar
Member Number: 1369
Finished the install of the lock bars for the storage boxes. I still need to reinforce them with solid rod plug welded inside the tube to make it harder to bend them. These bars are double duty, hopefully they will keep the boxes fairly secure and to hold a tarp down over stuff in the bed when it's fully packed.
78 Honda CB750K
11 Ranger S/C 2wd
