Go Back   IH PARTS AMERICA > Tech Forums > Suspension Tech
Old 03-06-2017, 08:54 AM   #1
Carl Wiese
Carl Wiese's Avatar
Member Number: 13
Default Shackle Questions
With this kit stock replacement shackle plate for 1971-80' Scout II, terra or traveler I am getting the 6 plates, then have to add the right and left plate for the sway bar?
The second question is, with the 5" plates the 4 degree shims are recommended. If my rusty memory is right, then 1980 front axle has 2 degrees of caster already in it. Would I still need the shims?
Thanks!
Certified 100% Grade A Prime Web Wheeler.
Carl Wiese is offline   Reply With Quote
Old 03-06-2017, 09:23 AM   #2
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: Shackle Questions
Originally Posted by carl wiese View Post
with this kit stock replacement shackle plate for 1971-80' Scout II, terra or traveler I am getting the 6 plates, then have to add the right and left plate for the sway bar?
The stock plates are all separately purchased and much more expensive to buy than our CPT ones. To order those correctly you have to put 6 plates at $12 each in your basket, then add the left and right swaybar plates at $26 each for a total of $124 to replace all the stock shackles.
Thanks!
If you have a 1980 Scout and are running stock springs then I would only add in 2 degree shims which we do sell separately.
CPT - Crawler Proven Technology steel caster / pinion shim set for Scout 80, 800, Scout II, terra
IH Parts America - Owner
Binder Books
(530)274-1795
Old 03-06-2017, 09:29 AM   #3
Carl Wiese
Carl Wiese's Avatar
Member Number: 13
Originally Posted by ihpartsjeff View Post
the stock plates are all separately purchased and much more expensive to buy than our CPT ones...
Jeff do you have a link to the CPT ones you're referring too? I am thinking I May just stay stock for now.
Old 03-06-2017, 09:36 AM   #4
ihpartsjeff
Member Number: 1
Sorry, what I meant was the stock shackle plates we sell(supplied by SLL) are much more expensive to buy than our lift style CPT shackle plates. We don't make a stock shackle plate under the CPT name. Hope that makes better sense.
Binder Books
(530)274-1795
