Old 04-06-2013, 06:44 PM   #1
kjc-01
kjc-01's Avatar
Member Number: 1174
Default new water tube leaking
While replacing the water pump on my '70 1200d 345 I made the mistake of removing the water tubes. After buying new water tubes and o-rings from ihoa, I cleaned up the bores with a brake hone. O-rings were dressed with hyomar and tubes installed for a coolant flush. Water poured from the passenger side water tube/water pump housing joint with zero pressure on the cooling system. I removed the tube and re-dressed the o-ring with fresh hylomar and got the same effect.
My plan is to find the next size bigger o-ring (2-217 with the 1-3/16 id instead of the stock 2-216 with the 1-1/8 id) and verify the location where the o-ring seats in the pump housing is defect-free. I think the hylomar is made more for dressing gaskets and sealing joints rather than sealing o-rings since it is so stiff once the solvent evaporates.
Does anybody have recommendations for an alternate o-ring sealant like permatex form-a-gasket #2 or plumbers grease?
kjc-01 is offline   Reply With Quote
Old 04-06-2013, 08:21 PM   #2
Major Screwup
Major Screwup's Avatar
Member Number: 537
Default Re: new water tube leaking
Those tubes move around with expansion and contration, so don't use a sealer that will harden. I've used waterproof silicone grease with good luck.
The oring makes the seal not the goop.
A bigger oring won't work, but you might try a couple wraps of teflon tape on
the tube before ya put the oring on.
Party like it's Dec. 16 1773
It takes a lot of balls to build bearings
440 Scout ll
15 CTS-V
Major Screwup is offline   Reply With Quote
Old 04-06-2013, 08:59 PM   #3
Scoutboy74's Avatar
Member Number: 453
Hopefully you didn't remove too much metal with the hone. I recently did this job on a 345. All I did was wire brush out the holes on the pump housing and cylinder head. Then I moistened the new o-rings with brake fluid. The o-ring lips/grooves on the water tubes weren't in that great of shape either, but it didn't matter. Both tubes sealed up tight as a drum on both ends even under pressure.
Scoutboy74 is online now   Reply With Quote
Old 04-08-2013, 11:29 AM   #4
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
For referance.
The o rings only need a bit of lube to assist compressing as it slips in. Also you should have to apply a good bit of force to get the tube in place. Try a bigger ring as you or some one else mentioned... Many times erosion and or po working can increase the bore.....
If you have pitting a bit of sealant can be used to fill them but not to smother the ring.
Robert Kenney
Old 04-08-2013, 05:59 PM   #5
dkminors
dkminors's Avatar
Member Number: 1337
I did use a bit of hylomar on mine and it seemed to work fine.
1975 Scout II 304 4-speed
dkminors is offline   Reply With Quote
Old 04-17-2013, 09:35 PM   #6
kjc-01
kjc-01's Avatar
Member Number: 1174
I think I have solved the leaking problem. The o-rings were rolling out of their glands during tube installation, most likely due to the tacky hylomar. I cleaned the hylomar off the o-rings, tubes, heads, and water pump with acetone, lubed the o-rings and id of the holes with silicone grease, and after multiple attempts was able to coerce the tubes in without the o-rings squirting out of their glands. I test fit a set of 2-217 o-rings during this and they did not fit snug on the id, so did not use them. No leaks were seen during a hose flush of the cooling system. Next step is running under pressure once I get the new thermostat in.
Old 04-29-2013, 08:20 PM   #7
kjc-01
kjc-01's Avatar
Member Number: 1174
Default Success!
I am happy to report that the cooling system has been reassembled successfully and run with a 7 psi cap with no leaks. I am not brave enough to run the 16 psi one on this stock radiator. Thanks to the new water pump, thermostat, gaskets, water tubes, o-rings, and hoses from IHPA and this forum for all the help.
Old 01-01-2016, 07:12 PM   #8
chopperkarl
Member Number: 5523
I was having same problem getting the water pipe to seal. Finally, I coated the channel where the o-ring seats onto the pipe with permatex #3 aviation sealant. I let it dry for an hour (to get tacky) then carefully put the o-ring on top (making sure no sealant got on the o.d. I let the pipe dry for 48hrs, then coated the I.d. Of the water pump with silicone grease. After assembly it held water. Hope this helps the next guy.
-karl
chopperkarl is offline   Reply With Quote
Old 08-22-2017, 02:47 PM   #9
MedMarine64
Member Number: 6422
Default Re: Success!
My mechanic friend is unsure how to mount the new thermostat housing gaskets; help needed Now please as I did not remove the old ones.
MedMarine64 is offline   Reply With Quote
Old 08-23-2017, 02:05 AM   #10
1975IH200
1975IH200's Avatar
Member Number: 731
Mount them so that the holes line up, vertically.
One (1) water hole and two (2) bolt holes.
I will withhold comment on your mechanic.
