Old 03-22-2018, 07:55 AM   #1
fungusdavej
Member Number: 9189
Default 196ic and 196 difference
I am brand new here and have been searching for this answer for about an hour with no luck! If I should have searched longer - sorry!
I have a 1979 Scout 2 4x4 with a 196 I just bought a few weeks ago. I am trying to figure out if it has the "improved cooling" or " enhanced cooling" (depending on where you look) because I want to order a gasket kit to take care of a small oil leak. Is there a quick trick or something stamped on it that will give me an answer?
Thanks in advance for any help!
fungusdavej is offline   Reply With Quote
Old 03-22-2018, 08:19 AM   #2
1975IH200
1975IH200's Avatar
Member Number: 731
Default Re: 196ic and 196 difference
An "IC" or Improved Cooling engine has the steel water tube(s) attach to the engine block. Non-improved cooling or the original design, the steel water tube(s) attach to the cylinder head(s).
Old 03-22-2018, 08:35 AM   #3
fungusdavej
Member Number: 9189
That's easy! Thanks
Tags
196, enhanced cooling, gas engine, i-4, improved cooling
