Old 04-24-2017, 01:01 AM   #1
Blasttruck
Member Number: 7854
Default black foam in coolant after top end rebuild
Greetings all!!
Another mess I'm in,
had a leaking head gasket in my 1972 345 and even though 2 bottles of blue devil was helping I decided to do a top end and take care of it. Finally got it done and the next day opened the radiator cap and found a horrible black foamy froth. The oil seems fine and has no coolant. I ran a hose into the radiator for about 10 minutes to see if maybe it was just gunk or residue but came right back. There are small bubbles coming up while she runs as well. Also put in a new water pump last week. I'm guessing something went wrong but figured I'd check with you guys first....I'll try to post pics...
Blasttruck is offline   Reply With Quote
Old 04-24-2017, 06:15 AM   #2
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: black foam in coolant after top end rebuild
Looks like someone put some "stopleak" type product in it before and now its coming back to bite you. My suggestion would be a coolant flush and possibly even removal of the lower block freeze plugs to check for gunk and remove as needed. Pretty common to see a bunch of gunk in the block, especially if the engine wasn't taken well care of. But the bubbles coming up to the top of the radiator while the engine is running is interesting. Have you preformed a cooling system pressure test after replacing the cylinder head gaskets?
IH Parts America - Owner
Binder Books
(530)274-1795
Old 04-24-2017, 09:42 AM   #3
Blasttruck
Member Number: 7854
Thanks Jeff,
I put the 2 bottles of blue devil head gasket sealer in, also if I remember correctly a bottle of bars a number of months ago. I have had 2 separate freeze plug issues, a replaced water pump and did a radiator flush all on separate occasions so there has been many water changes over the last 6 months or so. There's no telling what the po had done! I should also mention that I am only running water right now and my heater is a warmer. I haven't checked or know the correct way the heater hoses go to the fire wall either so if he hooked those up backwards maybe it's gunk from the core....?
I have not done a pressure test and it's only been running for 1 full day since the work....could I possibly just have some not tight enough gaskets or maybe plugs?
I'll try running a bunch of water through tonight again and see if there's any improvement. .....
Old 04-24-2017, 10:54 AM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
You really want the block tester kit with the blue die that changes color if hydrocarbons are detected in the coolant system. The kit is around $25 at most stores and will give you a definitive answer as to what the bubbles are. All that clean water May be dissolving some of the deposits in the block or bottom of the radiator. I hope your head gaskets are sealed. Were the heads checked for cracks? And what cylinder(s) were leaking?
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 04-24-2017, 11:05 AM   #5
Blasttruck
Member Number: 7854
Hey fd,
I will get that when I get a free second. Just went and checked, the valve cover bolts were very loose as we're the valley cover bolts. Also my heater hoses were loose and one was slightly dripping. I think it was 5 and 7 were where we saw the leak. The whole gasket was a mess though. The good (?) news is that I didn't have any major gunk just now when I checked her! A few specs of copper from some old sealer, but maybe she's getting pretty flushed!!??
Still very appreciative for any thoughts or insight!
Thanx guys!!
Old 04-24-2017, 11:51 AM   #6
Blasttruck
Member Number: 7854
Ps, doubt it matters much but all new brass plugs I head and block, also had the intake and a few other small parts hot tanked,cleaned, and painted....
Old 04-24-2017, 04:58 PM   #7
Scoutboy74's Avatar
Member Number: 453
The loose bolts you found wouldn't lead to the gunk in the radiator, but if the same loosey goosey wrench turner did the cylinder head install, I'd be questioning if proper torque was achieved at the head bolts. Those are very critical and need to be done in stages and in the proper order.
Old 04-24-2017, 06:52 PM   #8
Blasttruck
Member Number: 7854
Well, I think I have a good update...for once lol.
No more gunk! Looks like this May have been a mess of previous stop leak and dirt from the past as Jeff said. I think the foaming aspect May have been from the air bubbles, which have also seemed to have stopped, mixing with the stuff. I think the bubbles were from the small leak at the heater hoses allowing air into the system. Just to verify: does the heater hose from the thermostat housing go to the top inlet to the firewall..??
There was a bit of steam from the drivers side tail pipe after sitting for a few hours today but maybe that was from condensation. ...
scoutboy, we were pretty vigilant in tightening the bolts gradually to spec on the heads and manifold in the x or outward pattern . I think tomorrow night we are going to run a compression test and a pressure test on the radiator .
let's hope this was just a disgustingly, scary, much to do about nothing!!
