Old 10-24-2011, 06:53 PM   #1
jllamas74
Member Number: 3999
Unhappy Placement of Oil pressure and temp parts?
I've got a 72 Scout II and I just rebuilt my 345 and when putting all back in I noticed I didn't Mark where the pressure and temp plugs go and I'm in need of help badly. If there's any way I can get help on here it would be much appreciated. Thanks!
jllamas74 is offline   Reply With Quote
Old 10-24-2011, 07:04 PM   #2
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: Placement of Oil pressure and temp parts?
I am assuming you are referring to the oil pressure and coolant temperature senders.
The oil pressure sender goes on the drivers side of the engine just above the pan rail. Any one of the 1/8 npt threaded ports will do but usually one nere the middle is the place for the oem.
The coolant sender goes in thermostat housing or front of the intake manifold in a water passage
Robert Kenney
Old 10-24-2011, 08:20 PM   #3
jllamas74
Member Number: 3999
Yes those, my bad and thank you very much. And I realized this post is in the wrong forum, sorry about that.
Tags
345, engine, oil, scout ii
