Old 09-11-2012, 08:00 AM   #1
maunster
Member Number: 4966
Default 196 oil capacity
Hey guys, I know this is a stupid question....but, whats the official oil capacity for the 196?
I looked through engine specs, forums, etc. And come up with no for sure number. I obviously can make a pretty close guess, but I'm curious as to how much you guys would put in yours.
maunster is offline   Reply With Quote
Old 09-11-2012, 08:17 AM   #2
jeff campbell
Member Number: 39
Default Re: 196 oil capacity
Say's in owner's manual...only thing I can find it in is an old motors manual,'61-'62 152,4 qts. Put 4 in,run an check,depending on what filter u have,will prolly take maybe 5 qts.? Just be easy an fill an check. Jeff
jeff campbell is offline   Reply With Quote
Old 09-11-2012, 08:41 AM   #3
maunster
Member Number: 4966
Thanks! I put 5 in then a pint of the zinc treatment and the oil level on the stick is halfway up the "full" lettering. This sound close enough?
Old 09-11-2012, 08:51 AM   #4
jeff campbell
Member Number: 39
Should be,in the v8's can run a qt., overfull,no problems,Jeff
Old 09-11-2012, 12:59 PM   #5
maunster
Member Number: 4966
Ok thanks! If anyone does anything different let me know.
Tags
capacity, oil
