Old 03-25-2013, 11:09 AM   #31
Caperodder
Caperodder's Avatar
Member Number: 514
Default Re: 345 Rebuild
Yes, that's #3.
#3, #5 and #7 shaft stands have the holes, but only #3 (drivers side), and #7 (passenger side) have corresponding holes on the head itself. All are clogged.
The po ran the engine for me, but after 30 seconds, I told him to turn it off. Lots of engine noise. As I have been tearing this engine down, and inspecting/measuring everything, it's apparent that all the noise was in the top end. Cam, lifters, rockers etc. I could tell by the existance of a newer head gasket, and the globs of rtv, that someone had there hands on the top end. The good news is that all of the cam bearings are still intact and are not in the pan. Of course all of these components will be replaced.
Another interesting note. There are no welch plugs on the end of the shafts. There is no way that these shafts were filling with oil, and pushing their way out the top holes in the rocker shaft. I guess the "builder" thought them unimportant. The shaft itself is caked with burnt oil and carbon deposits.
-brett
1972 Scout II
1971 Scout II (810) Half Cab
Caperodder is offline   Reply With Quote
Old 03-25-2013, 05:23 PM   #32
karshopkevin
Member Number: 2406
Great thread ,great pictures, makes me want to get started on my 392ic. Please keep it going .kevin
karshopkevin is offline   Reply With Quote
Old 01-24-2018, 12:17 PM   #33
Caperodder
Caperodder's Avatar
Member Number: 514
Ok. Deep breath. Been away a long time working in a Cyber Security startup, so I haven't had much toy time.
Heads are now finished, and I'll post pics by the weekend.
I'll be back on the block by the weekend as well. Where I left off was getting proper measurements regarding the depth of the pistons in their bore, and calculating "quench".
Question is.....what happens to the intake manifold as we remove material, (maybe .030-.040") from the block? I take it that the new gaskets put the heads back at the proper height and therefore no mismatch or alignment issues?
-Brett
1972 Scout II
Old 01-24-2018, 01:10 PM   #34
FDChappie
FDChappie's Avatar
Member Number: 3742
I did this on my 345 block. IIRC the OEM steel shim head gaskets are .016. The modern FelPro gaskets are .040. Again IIRC there was .035 shaved from deck and the heads were surfaced .010. The intake manifold fits perfect and I think I have about 9:1 CR. Compression tests on the engine show 160 psi with a stock 345 is around 130-140 on the same gauge. The engine runs great on 87 octane fuel.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 01-25-2018, 05:29 AM   #35
Caperodder
Caperodder's Avatar
Member Number: 514
OK. Got it!
So.....IIRC, we need the pistons to be flush or pistons slightly under or deeper, say .005 or so?
I'm about .048 deep in the hole now, (see previous pics). That, plus the .016 original shim type gasket gave me ~.064. New Felpro jacks that up to .088. I'm looking at lopping off well over .050.
What say you folks?
-Brett
1972 Scout II
Old 01-25-2018, 12:52 PM   #36
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Optimum quench is considered .035-.040" on a new tight engine. By ~ .055 the quench effect is considered gone.
Zero deck to .005 in the hole would be perfect for a .040 HG. I don't recommend less than .035 on a SV.
Robert Kenney
Old 01-25-2018, 02:13 PM   #37
Caperodder
Caperodder's Avatar
Member Number: 514
You mean 0 - .005 in the hole would be perfect, yes?
Nice to be working with you again Mr. Kenney!
-Brett
1972 Scout II
Old 01-25-2018, 03:20 PM   #38
FDChappie
FDChappie's Avatar
Member Number: 3742
Correct, that's what Robert me too. My machinist was not comfortable going that far due to intake manifold and push rod issues. While I don't have all of Roberts fancy measurement tools, with the pistons down .010 the manifold fits fine and one of the valves clacks a bit when really cold until it warms up so plenty of clearance there. My engine is running a Comp 252 cam and lifters.
Old 01-25-2018, 03:35 PM   #39
Caperodder
Caperodder's Avatar
Member Number: 514
Thanks. Can’t wait to get going on this again. Before I have the block decked, I’ll need to make sure I’m going to be using the stock pistons. Those measurements will happen next.
Thanks.
1972 Scout II
Old 01-25-2018, 05:03 PM   #40
Robert Kenney
IHPA Tech Moderator
Member Number: 543
-Brett
Yikes!!!! who proof read my post. Nobody. Corrected I hope.
Always check intake manifold alignment in a mock up before committing yourself. Machining the manifold is fairly easy for a shop. Don’t let it cause poor decisions. Set it up right.
Robert Kenney
Old 01-26-2018, 07:41 AM   #41
Caperodder
Caperodder's Avatar
Member Number: 514
Ha! .005, .050, no big deal.
-Brett
1972 Scout II
Old 01-29-2018, 08:20 PM   #42
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Ha, I found 4 errors.
Robert Kenney
Old 01-31-2018, 08:21 AM   #43
Caperodder
Caperodder's Avatar
Member Number: 514
I want to pick up a Flex Hone and do a very minor glaze break in the cylinders before I put the pistons back in for final measurement. What I see available is 3-3/4 or 4-1/8. With a bore of 3-7/8 will the 4-1/8 be ok?
I've only used the spring loaded stone type honers in the past vs the flex hone brush style.
Thought I'd check.
Also, what grit would be recommended? Available are: 120/180/240/.
Thanks!
1972 Scout II
Old 01-31-2018, 10:52 AM   #44
Robert Kenney
IHPA Tech Moderator
Member Number: 543
That should be OK from a diameter perspective. The hone is designed to work in a 4-1/8 bore so it is bigger than 4-1/8.
I would use the 240 for the finish hone.
Robert Kenney
Old 01-31-2018, 11:02 AM   #45
Caperodder
Caperodder's Avatar
Member Number: 514
Just found a 4". I'll go with that.
1972 Scout II
