Old 01-16-2018, 05:20 PM   #1
LutzCoyote
Member Number: 8709
Default 304 Vacuum or other problem
Fellow IH Members,
I have 72 Scout with the 304 engine. I've noticed lately I'm starting to see some oil around the EGR Cap Plate, Spark Resistor port. below the Drivers side Valve Cover and behind the Valley Pan on the tranny tunnel below where the PVC valve is located.
My question is could a Vacuum issue be causing the odd leak locations of is it just valve Cover and manifold gaskets that need replacing or something else all together?
I'd appreciate any and all assistance.
LutzCoyote
LutzCoyote is offline   Reply With Quote
Old 01-16-2018, 10:01 PM   #2
FDChappie
FDChappie's Avatar
Member Number: 3742
Default Re: 304 Vacuum or other problem
If the valve gaskets are over 5 years old, I'd start by replacing them.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 01-17-2018, 08:43 AM   #3
Scoutboy74's Avatar
Member Number: 453
Have you verified function of your PCV and EGR valves? There could be excess pressure building up inside the crankcase looking for easy places to escape...aka blow-by. How many miles on this engine? Have you tested compression lately?
Old 01-17-2018, 02:00 PM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
Agreed ScoutBoy, I had a 345 blowing oil out of the dipstick under load because the PCV and Flame Arrester were plugged.
Old 01-21-2018, 01:23 PM   #5
LutzCoyote
Member Number: 8709
Scout. I haven't and that's a great suggestion, I'll update once I check.
Old 01-21-2018, 01:25 PM   #6
LutzCoyote
Member Number: 8709
I'll check the spark arresttor also..Do you know where I can get a replacement?
Old 01-21-2018, 04:36 PM   #7
FDChappie
FDChappie's Avatar
Member Number: 3742
soak it with carb cleaner until it runs out clean. It is just a copper mesh screen in side.
