Old 09-23-2017, 05:40 PM   #1
DANINCO
Member Number: 5328
Default 392 valves in a 345 head
Has anyone ever put the larger 392 valves in a 345 head?
DANINCO is offline   Reply With Quote
Old 09-24-2017, 11:34 AM   #2
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: 392 valves in a 345 head
Not me personally, but it is a normal process to go through in an attempt to find hidden power.
The 392 has a bigger bore and hence more room to fit the bigger valves and not hit the bore while open.
Standard 345 valve stems are 3/8 the 392 has a bigger stem on the exhaust valve .414-.415.
From a flow standpoint the IH SV heads are anemic at best. It would most likely be a waste of money.
Robert Kenney
Old 09-24-2017, 06:44 PM   #3
FDChappie
FDChappie's Avatar
Member Number: 3742
IIRC 392 pistons are notched to clear the valves too.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 09-25-2017, 05:13 AM   #4
DANINCO
Member Number: 5328
clip Re: 392 valves in a 345 head
Pics of valvetrain. 58 cast steel rockers bushed. Plated shafts.
