Go Back   IH PARTS AMERICA > Tech Forums > Diesel Engine Tech
Old 08-19-2017, 01:03 PM   #1
Member Number: 3442
Default Gearing
I have my 72 scout with the nissan sd33t ,t19 4sd, dana 300 with 44 frunt and rear running 33/12.50s. My qustion is what gearing are people running with this set up to go down the road at 65 but have the little extra power from the gears to pull a hill? I have 3.73 but and thinking 4.10 or 4.56 gears . Any input would be great. Also thinking of swaping in the nv4500 at some point. Thanks
nick is offline   Reply With Quote
Old 08-19-2017, 04:07 PM   #2
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Re: Gearing
4 Speed? You want to cruise at your highway speed at or just above your engines peak torque. Split the peak torque rpm and the peak hp rpm (3000 rpm) for better power. The closer you are to peak hp the more wear and tear you have but more surplus power.
Do these specs look right?
DISPLACEMENT: 198 cid (3,246 cc)
BORE & STROKE: 3.273.94 in.
POWER: 101 hp @ 3,800 rpm
TORQUE: 175 lb-ft @ 2,200 rpm
5 speed: use 4th as a hill pulling gear.
Lots of rpm calculators out there. Punch in the variables and see where you end up.
Well I couldn't wait.
@ 65 in 4th gear (1-1)
Robert Kenney
