Go Back   IH PARTS AMERICA > IH Parts America Area > New Products at IH Parts America
Old 09-07-2017, 08:57 AM   #76
Mark Pietz
Member Number: 2143
Default Re: Aluminum Radiators for Scout II
Originally Posted by Craig View Post
The switch that connects to the radiator, is opened once the scout is up to temp. One could use any water port on the intake or tstat housing if need for smog verification. Unless you don't mind welding a port on the radiator.
These were used on the 345 79/80 Scouts and the radiator is the specific place where they were "needed". IIRC, this is where it is shown on the smog decal. Having gone through several CA inspections with an '80, I don't know that I'd risk failing the visual by eliminating it.
Old 09-07-2017, 09:22 AM   #77
Michael Dimock
IH Parts America Sales Assoc.
Michael Dimock's Avatar
Member Number: 581
Eric,
The two small fittings in the radiator are for the transmission cooler and both will have a line going to the transmission. The orientation of the lines doesn't matter if you are routing new ones. Thanks.
Workin' at IHPA
Michael Dimock is online now   Reply With Quote
