Go Back   IH PARTS AMERICA > Tech Forums > Axle Tech Questions
Old 07-23-2017, 08:10 PM   #1
chopperkarl
Member Number: 5523
Default Troubleshooting dana 44
I have a 1973 Scout II w the stock Dana 44. It seems to be becoming positrac on its own. When I jack both wheels off ground and tun 1 wheel, they both turn. There is no resistance, but both wheels turn as if a solid axle. If I jack one wheel up (other wheel on ground) it takes 10 to 20 pound of break-away force to rotate the raised wheel. Once I get it moving it has less resistance but there is still some there (maybe 3-4 pounds to keep it rotating). There is plenty of oil in the diff. The driveshaft turns freely as long as both wheels are free to turn at same time. Any ideas what the problem/fix is?
Thank you
-Karl
chopperkarl is offline   Reply With Quote
Old 07-23-2017, 08:19 PM   #2
FDChappie
FDChappie's Avatar
Member Number: 3742
Default Re: Troubleshooting dana 44
Sounds like you've got a limited slip axle.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 07-24-2017, 04:34 PM   #3
chopperkarl
Member Number: 5523
Thanks Chappie. Limited slip was my initial thought. However, it seems to be getting more limited and less slip. Is this possible? could it be initial signs of a problem or danger? I'm getting smarter as i keep working on the truck, but no experience w axles yet. No problems when driving. I notice it when rolling it in the garage or driveway as a minor shutter when one wheel breaks away from the other.
Thanks
-Karl
Old 07-24-2017, 08:08 PM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
If you're using oil without limited slip additives, yes. The clutches will begin to chatter on corners too.
