Old 01-18-2011, 07:51 AM   #31
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: Matt's Full Width Scout II
Originally Posted by nate46and2 View Post
this is a simple question. When you install a Chevy full width front Dana 44 on a Scout II you said the front spring perches are about a 1/2 inch off from lining up. Do you just move the drivers side perch over or how do you get it to match up with the Scout II springs? Thanks
nate r spence
The driver side perch is cut off and either moved over or replaced. The passenger side gets a new hole drilled in the casting right next to the old hole. Both sides most be moved equally or as close to otherwise your axle will be offset to one side or the other.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 01-18-2011, 02:36 PM   #32
Joe M
Joe M's Avatar
Member Number: 1703
Originally Posted by scouty View Post
hood louvers and fan shroud
Installed a set of hood louvers from Jeff. Placement over the manifolds really lets the heat out . I added a fan shroud (from IHPartsAmerica) and cut out part of the inner fenders at the same time I added the louvers, so the engine temp went down considerably. Also noticed a big difference in the under the hood temp, you can actually feel the heat coming out the louvers when you put your hand over them. The reduced heat also makes it nicer in the cab, before these latest mods it felt like the heater was on all the time, especially when the side vents were open. Now when the vents are open you can actually feel cool air coming in. Added a new SSII grill (from IHPartsAmerica) while I was at it.
I dont suppose you have a pic of the underside of the hood with the 3 new holes in it? Im interested in the concept but dont want to cut the integrity out of the large size heavy hood. Did the scoop go over the spot where the "o" is in the middle of the hood or did you have to weld in new bracing? Thanks-
Joe m
ps-
this is one sick truck, well done
Joe M is offline   Reply With Quote
Old 01-21-2011, 12:17 AM   #33
mike hayes
Member Number: 1623
I want one of those front bumpers what kind is it
mike hayes is offline   Reply With Quote
Old 01-24-2011, 07:06 PM   #34
Scouty
Scouty's Avatar
Member Number: 8
I will snap a couple of pics of the underside of the hood tomorrow and post them, but the hole was cut out right where the "o" is under the hood so the integrity of the hood is not jepordized.
If you were refering to the front bumper, it's a warn bumper that came off a Jeep. It had to be modified, but has worked pretty good even with the winch.
73 Scout II
74 Scout II
Scouty is offline   Reply With Quote
Old 02-21-2011, 12:16 PM   #35
Scouty
Scouty's Avatar
Member Number: 8
Sorry it took so long.
73 Scout II
74 Scout II
Old 03-03-2011, 07:52 PM   #36
gulfdawg
gulfdawg's Avatar
Member Number: 771
Put me on the list for an emissions sticker. Actually 2.
74 100 4x4 392/Auto/NP205 D60/14Bolt
72 Scout II 345/Auto/D20
2006 Scout....My dog.
2012 2500 6.7 CTD Mega Deleted by Dave Mathews
gulfdawg is offline   Reply With Quote
Old 04-24-2011, 08:06 PM   #37
shoobear
Member Number: 962
What rear springs did u use?
4" lifted Scout springs?
shoobear is offline   Reply With Quote
Old 06-24-2011, 06:12 PM   #38
vancetater
vancetater's Avatar
Member Number: 3437
Those stickers are awsome I could go for a few of them I got $$$ if that helps also I dig the hood vwnts and cowl
vancetater is offline   Reply With Quote
Old 08-02-2011, 02:11 PM   #39
WhiteDuke
Member Number: 3704
Thumbs up Re: Matt's Full Width Scout II
I really like the hood vents and cowl! How much do those run? I can't find them on here...
WhiteDuke is offline   Reply With Quote
Old 08-04-2011, 10:29 AM   #40
ihpartsjeff
Member Number: 1
We no longer stock the hood vents but if you call us we can special order in a set for you.
Binder Books
(530)274-1795
Old 08-20-2011, 08:17 AM   #41
waltrobak
Member Number: 3782
How does this SOA lift handle on the road or the highway? By going with the wider differentials did this give you a lot better stability and control in normal road driving conditions? I am looking at doing the very same thing, but I am listening to a lot of negetivity about doing an SOA lift. I currently have a 4" suspension lift, 1-1/2" shackle lift and a 3" body lift, but I am looking to go a litle bt higher and would like to eliminate the body lift. What do you think and any suggestions? Thanks
waltrobak is offline   Reply With Quote
Old 08-25-2011, 07:50 PM   #42
Scouty
Scouty's Avatar
Member Number: 8
The truck handles really well even with bias boggers. Yes being wider makes the truck very stable both offroad and on. If you are planning to do a lot of offroading I would recommend SOA, but if you're not going to be offroad much then stay spring under. I ran a 3 inch bodylift and 4 inch springs on another Scout and it handled like crap, SOA was 100% better. Hope that helps
73 Scout II
74 Scout II
Old 02-28-2012, 05:39 PM   #43
79scout-too
Member Number: 358
What lift springs were used for the axle swap?
Was the wheel base stretched?
Or are the front rs fangs installed in the recommended location (flush with the front cross member)?
I use what I got
79scout-too is offline   Reply With Quote
