Old 11-23-2008, 11:50 PM   #1
pineneedle
Member Number: 528
Default carrier bearings, pt. 2
P.s.: the I-h manual gives two torque values for the pinion bearing preload, one lower for used bearings, and one higher (20-40 in.lbs.) for new bearings. On the other hand, the Yukon gear booklet gives just one value, the same as the lower (used bearings) value of the I-h manual. So, which should I use?
Pineneedle
pineneedle is offline   Reply With Quote
Old 11-24-2008, 07:17 AM   #2
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: carrier bearings, pt. 2
With new bearings I usually set them up with around 25 inch pounds of preload.
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
