Old 03-26-2007, 06:23 PM   #1
shane
Member Number: 152
Default Which 44's?
I have a'66 Scout 800 and want to know what year Scout II Dana 44's to get? Are they all the same or are certain years better than others? Thanks.
shane is offline   Reply With Quote
Old 03-27-2007, 05:40 AM   #2
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Default Re: Which 44's?
74'-80' Scout II's. All of them were the same with the exception of 1980 which had 2 degrees castor built in.
Jeff Ismail
IH Parts America - Owner
Binder Books
(530)274-1795
Old 03-27-2007, 02:58 PM   #3
shane
Member Number: 152
Thank you.
Old 07-29-2008, 06:21 AM   #4
Matt Main
Member Number: 446
Which 44's had the 2 caster built in, front or rear? Is that negative or positive? Would make sense, to me, if we're just talking front axle with negative caster.
Matt Main is offline   Reply With Quote
Old 07-29-2008, 09:48 AM   #5
RobertC
Member Number: 517
Caster is a front suspension setup / adjustment measurement.
It "aids" a vehicle going straight down the road. And, it "aids" steering / wheel "return" when making a turn.
Caster is positive -- 2 degrees is the stock measurement / setting.
Negative caster will cause "steering problems" / "wandering".
You can read many posts here and on the bb about the effects of negative caster when people do "lifts" / SOA.
Jeff has documented the changes he has made on some of the "builds" he has posted on this site.
RobertC is offline   Reply With Quote
