Old 10-18-2017, 05:18 PM   #1
Zaedster
Future Owner of IH Parts America
Member Number: 7132
Default 1973 International 1210 Pickup Truck
~International Harvester 1973 Pickup~ $3,500 OBO Located in Grass Valley, CA
*2 Wheel Drive
*Manual T19 Transmission
*1210 Model
*304 V8 Needs to be Rebuilt (Makes a loud tapping noise) i/e. bad cam
*Fairly New Exhaust System
*Brakes are a little touchy but work
*All Turn Signals and Headlights Work
*Electric Fan Setup controlled by 2 toggle switches in the Cab
*Rust is present in the cowl.
*Denting is present on the passenger side
*Tailgate does operate now
*Driver side door drops down a little when open
*Tires are weather checked
*Factory Heater
*Radio Delete
*No Door Lock Keys
Equipped with a Holley Points Dist. The bench seat has a cover on it. The top of the cab has some random bolts on it for some reason. They do not seem to leak though. Driver side door internals are loose or was put together wrong because glass is loose.
Starts right up. It has a brand new Ignition switch, Distributor cap, roter, points set, and wires. Of course other actions were preformed to get this running. When running, it makes a loud tapping noise. Brakes are very touchy when touched but work. Electric fan setup works fine. Cooling system was topped off. This will drive onto a trailer. Tailgate is stuck. Rust is in the usual places like the cowl. Bulkhead on the bed is curved inward from something sliding onto it. It does have power steering that works great. Flashers work fine. Rust behind the glove box area. Headlights work. Any other questions, just message me.
Zaedster is offline   Reply With Quote
Old 10-18-2017, 05:22 PM   #2
Zaedster
Member Number: 7132
Default Re: 1973 International 1210 Pickup Truck
Old 01-08-2018, 05:55 PM   #3
Zaedster
Member Number: 7132
Still available.
Old 01-08-2018, 09:05 PM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
A good how to on restoring these rusted D series cabs might help a lot of us keep these wonderful trucks on the road.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
