Go Back   IH PARTS AMERICA > Tech Forums > Oil Tech
Old 07-15-2017, 02:10 PM   #1
dmf6978
Member Number: 8771
Default Oil choice for 1200C pickup.
what are the other guys using in terms of oil? Manual says 10-30 for normal weather conditions. Would you recommend synthetic or regular due to the age of the engine?
dmf6978 is offline   Reply With Quote
Old 07-15-2017, 03:50 PM   #2
Scout-It-Out
Scout-It-Out's Avatar
Member Number: 904
Default Re: Oil choice for 1200C pickup.
what engine? what kind of temp range do you drive in? (ambient)
i have a 304 v8 that's primarily driven off road. i run straight 30wt. my normal temp is 60 to 100 deg. F. 15-40 is also popular.
i wouldn't run 10-30w here, it's too thin for the temp and more prone to leak out. the same can be said for synthetic. it is slipperier than conventional oil and will usually make any leaks you have worse.
~Andy
KJ6IYM
1979 Scout II, 304, 3.73, 31" tires, Spartan locker in the rear, Powr-Lok front, Hydraulic Brake Booster, Custom bumpers
Scout-It-Out is offline   Reply With Quote
Old 07-15-2017, 05:16 PM   #3
1975IH200
1975IH200's Avatar
Member Number: 731
Swepco 306, 10W-30.
Old 07-16-2017, 10:44 AM   #4
dmf6978
Member Number: 8771
I am sorry for the ignorance level here, but I just looked at the door pillar and it says 1200B. I live in NJ so it gets pretty cold and hot in each winter and summer. It will be housed in a garage though, and hopefully by this winter I will have it insulated. Still trying to figure out which engine I have.
Old 07-16-2017, 12:05 PM   #5
DF Sales&Marketing
Oil Moderator
Member Number: 207
Our recommendation for your area & climate would also be the SWEPCO 306-10W30 Engine Oil
Swepco Oil Sales Representative
DF Sales&Marketing is offline   Reply With Quote
Old 07-16-2017, 12:09 PM   #6
dmf6978
Member Number: 8771
Thanks for the help. I did read that somewhere else today. I believe my truck takes 5 Qt but ill buy 6 in case.
