Go Back   IH PARTS AMERICA > Tech Forums > Brake Tech
Old 12-16-2017, 12:56 PM   #1
ASmith604
Member Number: 9042
Default Request For Assistance - Identifying Wheel Cylinder
Hey there fellow binderfolk! I've come across an issue with my truck and have hit a dead end in trying to identify a blown out wheel cylinder, hopefully someone more experienced can point me in the right direction. As per the sticky, I've filled out the prereqs to the best of my ability.
1) 1100
2) 1965 grill, but 1967 badges. "1000C". Has a dealer tag of "H.J. Mader" from Saskatchewan.
3) 2 Wheel Drive
4) 3 speed standard transmission
5) NA
6) B-264
7) Unknown
8) Gas
9) 4 wheel drum, 11x2.25 front shoe
10) Unknown
The wheel cylinder is a 1-1/8 bore dual piston, two-bolt style mount with a casting number of "2319". Attempts to cross reference this number have all been fruitless. In my search for information, I've come across two other owners with the exact same issue, neither of whom appeared able to find a solution. This unit is damaged irreparably and rebuilding is not an option.
When comparing the old cylinder to equivalents in part listings, everything else has a larger mounting "circle" on the back side and doesn't fit the cylinder. Listed jobber cylinders are identical to the mystery unit aside from this mounting incompatibility.
Past the immediate concern of lacking functioning brakes, I'm curious if I've inherited someone else's jimmy-rigging, or if this is an undocumented variation. As both the other records of this part issue I've found also come out of up here in Canada, perhaps this is something unique to binders built for north of the border?
ASmith604 is offline   Reply With Quote
Old 12-16-2017, 02:54 PM   #2
Scoutboy74's Avatar
Member Number: 453
Default Re: Request For Assistance - Identifying Wheel Cylinder
Nearly anything is possible with IHC. What are your rear axle brake shoe dimensions? Do you happen to have a legible copy of the line setting ticket? I suggest posting some pics of your wheel cylinders, including one with a tape measure nearby to show approximate size of your mounting circle. As a last resort, I'm wondering if you might be able to carefully machine out the mounting holes on your backing plates with a roto tool to accommodate the more readily available wheel cylinders?
Old 12-18-2017, 03:53 PM   #3
Greg R
Member Number: 527
Talk to the IHParts America folks that support this site. Send them a photo. As this forum just blogs and is supported by IHPA, we really cannot recommend other vendors. They have resources and parts not listed on their website, so an email or phone call is your best bet. I have a 1967 1100, and brake parts were not too difficult to track down. Casting numbers are many times not relevant, but year/make/model/platform are.
You can also ask folks over at Binder Planet to widen your search.
Old 12-19-2017, 05:24 PM   #4
darren y
Member Number: 845
http://www.rockauto.com/en/catalog/i...+cylinder,1952
To many Binders, hit me up for parts....
4-sale?:
Early 60's Metro (it runs/drives/stops!)
Many 60's trucks/t-alls
71 1600 frame
71 1110
73 1500 frame
77 Scout II crawler
72 Scout II frame/tub (lifted/rvrs shackle)
77 IH School Bus
+ several sheds full of IH Parts….
Not 4-sale:
(2) Scout II's,
(2) 60's truck/t-alls,
56 S-160 ('Mater project)
71 1600 Loadstar crewcab
(always looking for 60's Truck/ T-all parts)
775-720-3998
darreny@charter.net
Instagram: @ihaddict
darren y is offline   Reply With Quote
