Go Back   IH PARTS AMERICA > Tech Forums > Brake Tech
Old 07-18-2017, 07:19 PM   #1
LutzCoyote
Member Number: 8709
Default 72 Scout II Power booster addition Questions.
Good Evening,
I'm about to install a new Master Cylinder/Power Booster Combo to my 72 Scout II which currently has only the master cylinder. It also has been converted to disk brakes all around, so I have just a few questions to understand what entails this conversion.
On the 304 engine does the Booster Vacuum Line connect directly to the Manifold or to a T fitting in the PVC hose?
Do I need to change the proportioning valve that is currently in use with just my standard brake setup and if so, what valve would I need?
Thanks,
Sam
LutzCoyote is offline   Reply With Quote
Old 07-19-2017, 03:50 PM   #2
1hc72
Member Number: 991
Default Re: 72 Scout II Power booster addition Questions.
did you have a disc/drum or a drum/drum before?
what do you have now? if it a disc/disc you will new a new prop valve.
far as the vac line i THINK it comes righ off manifold.
19723 international 1110 travellette
4wd d44 /d60345/tf727,unkown tcase 3.73 gears
1hc72 is offline   Reply With Quote
Old 07-19-2017, 04:22 PM   #3
LutzCoyote
Member Number: 8709
Hi IHC72,
Thanks for the response.
I'm not sure what the truck had before I purchased it but the Master cylinder and proportioning valve look to be original to the truck. If I had to venture a guess I'm pretty sure it was disk/drum before.
I'll take a look at the manifold since it's an original with for a 2bbl carb and see if there's a been a plug installed.
If there's no plug I'm still looking for suggestions on how to connect the brake booster vacuum lie.
Thanks Again,
Sam
Old 07-20-2017, 08:35 AM   #4
FDChappie
FDChappie's Avatar
Member Number: 3742
Not likely as disk brakes first became available on Scouts in '74.
1974 Scout II 345 T-19
1971 Travelette 392 T-36
Old 07-20-2017, 11:16 AM   #5
LutzCoyote
Member Number: 8709
FDC,
Thanks for the info as I'm still learning about these Scouts.
Sam
