Old 12-19-2009, 01:35 PM   #1
Robert Kenney
IHPA Tech Moderator
Robert Kenney's Avatar
Member Number: 543
Default Differences 392 IC Vs NON-IC
Questions about ic vs non-ic sv392's have come up more than once. I wanted to post some photos to show the differences of the two versions while I have both in my garage.
The photo captions define what the image showing.
Name:  392fvIC (Medium).JPG
392 ic front
Name:  392fvNONIC (Medium).JPG
392 non ic front
Name:  392head pgNONIC (Medium).JPG
392 head plugged for 196
Name:  392headpgIC (Medium).JPG
392 head plugged for ic 392
Name:  392svleftIC (Medium).JPG
392 ic block left deck
Name:  392svleftNONIC (Medium).JPG
392 non ic block left deck
Name:  392svNONIC (Medium).JPG
392 ic block right deck
Name:  392svrightIC (Medium).JPG
392 non ic blockright deck
Robert Kenney
Old 12-19-2009, 03:36 PM   #2
Michael Mayben
Michael Mayben's Avatar
Member Number: 10
Default Re: Differences 392 IC Vs NON-IC
Thanks Robert!! We needed this thread!
Ya got comparison shots between ic and non-ic head gaskets? If ya don't I May have some.
Also, the intake manifold gasket(s) for an ic head (either set up as 196 or 392) have restricted rear water ports with a 3/8" hole.
The non-ic 392 and non ic 196 use intake gaskets that have no restriction in the rear water port. And those same intake gaskets are used in the 345 application.
http://vimeo.com/8149690
Old 12-19-2009, 07:26 PM   #3
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Here you go. Head gaskets for comparo.
Ic 392 head gasket
Name:  392 head gasket IC (Medium).JPG
Non ic 392 head gasket
Name:  392 head gasket NON IC (Medium).JPG
Robert Kenney
Old 07-01-2013, 08:28 PM   #4
Tiny Yokum
Tiny Yokum's Avatar
Member Number: 669
Thank you Robert. I have a ic392 in the works.
IH propane 152
HVACR Specialist
Tiny Yokum is offline   Reply With Quote
Old 02-18-2017, 06:41 AM   #5
PacificEd
PacificEd's Avatar
Member Number: 541
Are there any differences between the ic and non-ic heads themselves or just the block and where the water tubes enter?
Ed
1973 IH 1110 4x4 pickup
PacificEd is offline   Reply With Quote
Old 02-18-2017, 08:39 AM   #6
Scoutboy74
Moderator
Scoutboy74's Avatar
Member Number: 453
The heads are vastly different and cannot be interchanged. You can get a glimpse of the differences by looking closely at the pics that compare the intake manifold gaskets and also the head gaskets. There are obvious differences from stem to stern in both cases.
Old 04-28-2018, 10:52 AM   #7
Tiny Yokum
Tiny Yokum's Avatar
Member Number: 669
Wanting to put rebuilt 345e heads on a 1973, 392 improved cooling. 4v
I've heard of it done for performance reasons, probably not on non-improved cooling long block.
Engine runs good as is, future rebuild with or without 345e heads.?
392ic not pictured
IH propane 152
HVACR Specialist
Old 04-28-2018, 09:24 PM   #8
Robert Kenney
IHPA Tech Moderator
Member Number: 543
Since the 345 never came in the IC configuration, they will not work in an IC 392 block. Non IC 392? Possible
Robert Kenney
Old 04-29-2018, 07:26 AM   #9
Tiny Yokum
Tiny Yokum's Avatar
Member Number: 669
OK. Thanks Robert.
IH propane 152
HVACR Specialist
